Copper collector gaskets...do they work?
Old May 21, 2002 | 09:08 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I've replaced the gaskets on my collector gaskets more times than I care to count....I think it's time to try something different. I know the rubber donut gaskets work, but I"m worried about clearance problems. Do the copper gaskets work? Thanks
Old May 21, 2002 | 09:32 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Yes, they work very well. I've known people that put those on and never have to touch them again. I would reccomend them if you're having problems like that. There's also aluminum ones too, but I don't think there's a big difference between the two.
Old May 26, 2002 | 11:31 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mine have worked good for 4 days now
Old May 27, 2002 | 10:47 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Hey, that's longer than I've had some last :hail:
Old May 27, 2002 | 01:19 PM
VampireHunterC's Avatar
Can you get the copper gaskets from Autozone or Discount Auto or anywhere like that, or do you have to order them from Summit or Jegs? Also, do the make copper gaskets for headers?
Old May 27, 2002 | 02:11 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Yes they do make Copper header gaskets, you can also get those from Summit or Jegs....
Old May 27, 2002 | 05:35 PM
oriellys has copper gaskets both for the header and collector
Old Jun 2, 2002 | 12:36 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
aluminum colector gaskets
well mine burnt through and i cant seem to get anything to seal was even thinking bout using a stock "donut" gasket to help seal it but cant find 1
Old Jun 2, 2002 | 07:50 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Re: aluminum colector gaskets
Go to a local muffler shop....i have a donut on one side (long story), and it's been on there w/ no leaks for about 9 months.....all while i've gone through about 5 gaskets on the other side....bout to put on #6.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Fronzizzle
Aug 17, 2015 02:52 PM
