Headers Setup Help
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Headers Setup Help
I have a set of 2460-1 shorties hookers headers and want to know what is the best possible setup with these headers. I know there is not a Y-pipe for the header and I really want dual exhaust with maximum clearance. My mind is telling me to use X-pipe dual exhaust and flowtech mufflers. Nothing real loud, but excellent sound. Please give me some advice and recommendation.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
search dual exhaust and call all the exhaust shops in your area. i couldnt find one to run duals on a thirdgen. there are debates but i cant see why anybody would say duals are not as good as a single pipe. it will be more difficult to setup the exhaust though
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Couple things about dual exhaust...
1. Say goodbye to ground clearance
2. Can't use an x-pipe unless you want it to scrape the ground when you hit a pebble.
You can use an h-pipe though, but it doesn't help all that much performance wise (unless you're running a hot motor). You'll have to run the pipes next to the driveshaft and dump before the axle. You probably won't be able to find a shop to do this for you. What I'm doing is getting some flex pipe, bend it up how I want it, and then take it to an exhaust shop for them to bend up a real piece. If you need anything else, email me.
