possibility of having 2 mufflers???
Old Jun 7, 2002 | 11:08 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
hey guys-I was just curious if i could stick 2 mufflers under my car (one on each side) has anyone done this before-is it possible cause my mechanic says nope . . .
thanks
Old Jun 8, 2002 | 06:51 AM
Tas's Avatar
Tas
------> is your friend
Old Jun 8, 2002 | 06:52 AM
Tas's Avatar
Tas
w
Old Jun 8, 2002 | 02:23 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I have a 86 bird I use for street/strip action and ran into problems with true duals. For one the Heddman long tubes don't hang down low enough to clear tranny linkage/crossmember so it has funny bends and beat down on the exhaust pipe. Second, I used standard rectangle shaped mufflers-Flowmaster knockoff's- difference is Flowmasters are only 4" thick and mine are 5" thick. I beat the **** out of rear floor pans to get it hung up as close to floor as possible. With passenger and full tank of fuel I drag mufflers when I pull in and out of slightly up/downhill inclines. Then I had them turn out in front of rear tires. After I get tranny problem fixed I'm getting new exhaust system as the sponsor that put it on did a REALLY ****TY job to say the least, will never promote their bus. again cause alot of their work is way shoody. When I redo it though the turn outs will be facing each other under the car instead of down or sideways. This "helps" cancel the noise a little, plus when I start my car or pull it back into pit area I won't look like a helicopter landing on a sandhill. Guys give you funny looks when you blow dirt and dust towards their cars.
Old Jun 8, 2002 | 03:50 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Here's a 91 Camaro:
Old Jun 8, 2002 | 10:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
TAS, is that a 4th gen car that you posted pics of?
Old Jun 8, 2002 | 10:30 PM
91fbirdgta's Avatar
yea tas, the first pic is of a 4th gen car . . . my mechanic said something like it would be too close to the fuel tank or something . . .
and I know I could have used the search-but I guess I was being lazy
PurelyPMD
May 5, 2016 04:57 PM
rubblerubble
Mar 13, 2016 06:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
cstrobel65
Sep 16, 2015 11:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
