Need Help!!
Old Jun 14, 2002 | 09:23 AM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Need Help!!
WHAT IS THE EASIST WAY TO CHANG THE O2 SENSOR ON A 91 FIREBIRD? FROM UNDER THE HOOD OR UNDER THE CAR
Old Jun 14, 2002 | 10:28 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
If you have the tool to remove it, I found it to be about the same either way. You'll spend about the same amount of time doing it either way. I usually just do it from the top.
Old Jun 14, 2002 | 11:42 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
get the right tool from autozone. i did it from the top quick and easy
Old Jun 14, 2002 | 06:44 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Get a 7/8 O2 socket, swivel socket, and have enough extensions. Go from under the car and start from the front of the motor mount. That is what I have found to be the best. But I can also use a lift. The big key is the swivel socket.
