Components for 3 inch system...
Getting SLP 1 3/4 inch headers for dual cats... i want to have a shop build a 3 inch exhaust all the way to the muffler (80 series flowmaster)
I am prob blind
but i didnt see the sizes of the pipes coming out he headers to the cats.. are they 3 inch or 2 1/2 and if i want this 3 inch system made, will there be problems with it fitting under my 1992 z and for cats... i will need 3 inch inlets and outlets.. correct?
What cats shouldi look into, i see all kinds of different lengths like 16 inches and such, what type/ size cat do i need, and what company will flow the best, i wont be gutting the cat or anything, so i am looking for hte best flow/reliability out there...
Thanks.
I am prob blind
but i didnt see the sizes of the pipes coming out he headers to the cats.. are they 3 inch or 2 1/2 and if i want this 3 inch system made, will there be problems with it fitting under my 1992 z and for cats... i will need 3 inch inlets and outlets.. correct? What cats shouldi look into, i see all kinds of different lengths like 16 inches and such, what type/ size cat do i need, and what company will flow the best, i wont be gutting the cat or anything, so i am looking for hte best flow/reliability out there...
Thanks.
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If I'm correct the SLP Y-pipe output diameter is 3". I think you can purchase a dual cat adapter pipe or you can fabricate your own.
If you are gonna run dual cats do NOT get 3" in-out ones. I think you will need 2.25" in-out but I'm not sure. Somebody else here should have that answer.
Also on the cats:
I used Catco with no problems, cost was about $60
I looked into Ramdom Tech cats, but nobody could justify their high price.
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Stock dual cats are 2.5" inlet and outlet. From manifolds to cats are 2.25" pipes. From cats to y pipe is 2.25" pipe.
Pukka.... why would i not get 3" in/out for cats?
having the piping go from 3 inch to 2 1/4 inch will create some serious back pressure if i am not mistaken?
and 3" in/out would flow alot better, would i not?
Re: Components for 3 inch system...
Thanks for clarifying that for me...
I guess i'll leave the cats to the exhaust shop and just tell em to give me high flow cats... Anyone think they will actually give me high flowing cats?
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Were they an improvement
Originally posted by Pukka
Also on the cats:
Also on the cats:
thx,
RP.
who sells them ?
Originally posted by brodyscamaro
catco are supposed to high flow
thx,
RP.
Transmission: 4L80E/4L80E
Sometime within the past few weeks someone posted the p/n's for Catco direct fit dual cats. I believe it was Summit.
I know stock dual cats are 2-1/4". I would assume the SLP dual cat system uses the same size, but I don't know that for a fact. Some guys have gone dual 2-1/2", but IIRC, that was custom fabricated.
Catco are highflow. FWIW, I picked up a universal 2-1/2" from Checker for my van, it was the Walker brand, but was fabricated identically to the Catco I have on the Camaro.
LT1Formula
Oct 8, 2015 08:34 PM
