Headers have Air Tubes and i dont want them
Old Jul 3, 2002 | 07:52 PM
Gta-Paladin's Avatar
Bought SLP 1 3/4 Inch headers and i dont want them, can i just grind them of and plug them?
Old Jul 3, 2002 | 07:57 PM
89Irocz23's Avatar
What I did was grind them down and welded them at the top then sanded it semi what smooth. On my manifolds I had plugs I put in.
Old Jul 3, 2002 | 08:23 PM
Thanks JB weld?
Old Jul 3, 2002 | 10:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, not JB Weld. Can't take the heat, will exit the kitchen.
They offer them without the A.I.R. tubes. You'd be better served to return/exchange them for a set like what you want.
Old Jul 4, 2002 | 01:32 AM
Not really i live in canaDUH which means i'd have to pay shipping (50-75) and brokerage fees 70 dollars 140 plus the 1600 degree coating i paid 175 for....
I'll grind them down!
Old Jul 4, 2002 | 02:11 PM
rezinn's Avatar
They will rust where you grind them, since they will be uncoated.
Old Jul 4, 2002 | 05:15 PM
iroc22's Avatar
Its so rough living in Canda and trying to get some decent parts.
Maybe try and weld in the holes where the AIR was located.
Old Jul 5, 2002 | 10:52 AM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
SLP's are Stainless steel.
Old Jul 5, 2002 | 11:10 AM
1982chevycamaroz28's Avatar
if u can get ur hands on a tig welder up there. have some one tig weld the holes shut. if i was still in skool id beable to do it for nothing. and it would look great too.
Old Jul 5, 2002 | 08:42 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I cut the air tubes on my 1 5/8 headers, tapped the holes and threaded bolts in them. I then had the headers coated. I started getting O2 problems. The bolts were allowing O2 into the header tubes and messing up the O2 sensor. I took the car to a good welder and he closed the holes up permanently. My advice is to have them welded closed off the car. Then you can grind the weld smooth and coat the headers, minimizing discoloration from the welding and make the headers look nicer. (if that's important to you.)
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
FreeSpirit
Aug 29, 2015 05:47 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
drathaar907
Aug 6, 2015 04:20 PM
