Exhaust Smoke?
Old Jul 4, 2002 | 10:01 PM
mrremraf's Avatar
Car: 92 Camaro RS
Exhaust Smoke?
I have a 1992 Camaro RS 305. Everytime I start my car a cloud of white smoke comes out of my tail pipes. Does anyone have any reccomendations on how to get rid of this white smoke.
Old Jul 4, 2002 | 10:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
sounds like a possible blown head gasket. Do a wet compression check to see if you can find low cyls. If two that are next to eachother are low, thats a dead giveaway of a blown head gasket
Old Jul 4, 2002 | 10:32 PM
iroc22's Avatar
If it's a blue-ish cloud it's probably valve seals.
Old Jul 5, 2002 | 10:49 PM
mrremraf's Avatar
Car: 92 Camaro RS
How do I do a wet compression check?
Old Jul 6, 2002 | 07:51 PM
Car: 88 Camaro SC
Engine: SFI'd 350
to do a wet compression check, squirt a teaspoon or two of oil in before you insert your pressure gauge. This rules out the rings becasue it allows the to seal against the cyl. walls. This and the standard procedure for checking the compression are explaned in most shop manuals like haynes (crap), chiltons (fair) and helms (best).
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
84redta
Sep 19, 2015 09:58 AM
Accerrito22
Sep 5, 2015 09:34 PM
