Side pipes on a Thirdgen?
Old Jul 31, 2002 | 09:05 AM
nbn792's Avatar
Is it possible to fabricate and install side pipes for a third gen. I really want a mostly straight dual exhaust set up, but the stock pipe routing and ground clearance might pose a problem. So i thought what about side pipes, i would need the two lengths of exhaust tubing, larger tubing with a gizillion holes in it to go on the outside of it, a tube to patch it from my headers, and a way to get a muffler on each end. You guys are brilliant, whats your input?
Old Jul 31, 2002 | 10:34 AM
1985_glue_factory's Avatar
side pipes
You should do a search on this topic, it's been discussed many many times.
Old Jul 31, 2002 | 12:15 PM
nbn792's Avatar
i did do a search and the results were almost all negative feedback, and those that werent were mostly pictures. i really want STRAIGHT TRUE DUAL/ TRUE QUAD exhaust and looking at search for that showed that it doesnt work well unless: you want little ground clearance, $$$$, and reduced flow compared to most exhausts for the stock routing. Im planning to make a real mother of a motor, and i need a bad a$$ exhaust to boot. i was thinking dual 3/3.5/4, or custom headers and quad 1.5/2's. I hafta do some math, darn calculus, about what would flow the best and have the closest to ideal lengths and material values. Would custom true quad set up up with custom headers possibly alleviate the BB Header isuues?
Old Jul 31, 2002 | 07:12 PM
Nitroburn's Avatar
If you want to run "TRUE DUALS" all the way back, then you'll want to go NO BIGGER THAN 2 1/4 is pipes. There's no reason to go any bigger, plus it you do:
1) You'll lose a lot of low end torque as theres no much back pressure
2) You'll have the worlds worst ground clearence unless you make a 4x4 out of your bird.
Later,
Mike
Old Jul 31, 2002 | 09:14 PM
nbn792's Avatar
Not nessacary, im handy with a welder.
Im going full. near full race with my camaro, and i can due the math to predict what would be best and prove it on the dyno later. It needs to breath a lot, and the calculations for the anti reversion pipe have begun and that will alleviate most low and mid range tourque issues while barely touching high end power. Also stoking to 383 will give me a slight advantage over most in tourqe. Thanx any way, dont want to stir up any trouble.
Old Aug 1, 2002 | 03:43 PM
91 Camaro355's Avatar
i have a friend that had sidepipes on his car and he didnt really have much of a ground clearance problem wiht them and are town has some bad rodes but it can be done and it sounded good too
Old Aug 1, 2002 | 05:00 PM
psycomaross's Avatar
I posted this somewhere before but, WHAT THE HELL IS QUAD EXHAUST?
Old Aug 1, 2002 | 05:20 PM
nbn792's Avatar
4 exhausts.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
3rdgenparts
Aug 5, 2015 11:57 PM
