pipe fittings leak...please help!!!
Old Aug 4, 2002 | 12:18 AM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
I took off my smog pump today and a few members said to use 1/4" pipe fittings to plug the holes on the manifolds, but I'm getting a bad leak from them now, should I just torque real hard or should I have put something on them first to prevent leaking or what???? PLease help.
Old Aug 4, 2002 | 10:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Did you use pipe fittings, or flare fittings?
Pipe fittings will leak for 2 reasons. One, they don't seat on the 45* seat in the manifold. Second reason is 1/4" pipe fittings and 1/4" flare fittings are totally different sizes.
So there ya go,
AJ
Old Aug 5, 2002 | 01:07 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Why are ya'll taking the smog pump off?
Old Aug 5, 2002 | 11:11 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Unless you have emissions testing it's not needed. Besides it cleans up some space in the engine compartment.
Old Aug 6, 2002 | 10:06 PM
RICHRAD's Avatar
Smog pump removal gooood .........now yank those manifolds now that you can get to'em!
Old Aug 6, 2002 | 11:13 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
SHIIIIIIT you can have mine whith the plugs in 'em and everything you see in the pic!
Old Aug 6, 2002 | 11:14 PM
Car: '86 Trans Am
I also got free intake,Cylinder heads and carb for my LG4!
Old Aug 7, 2002 | 12:10 AM
jeffs82z28's Avatar
Smog pump good.
Goof ***** that dis-able emisions equipment bad.
With high performance catalytic converters available, and the negligable amount of power required to operat the A.I.R. pump, why would anybody decline to use it ?
I suppose if you like the smell of unburned gasoline so much, you could plumb the exhaust directly into the passenger compartment.
As for myself, I prefer clean air.
But, that is just my opinion, and I could be wrong
Old Aug 9, 2002 | 01:32 PM
SkyWarrior's Avatar
Engine: 305 LG4
I just had to torque them in some more and the leaks stopped. The engine bay looks a lot better without the pump, and I think I got close to fifty pounds off the front of my car. And Jeff, If you think the air that comes out of an AIR equppied car is clean, then why don't you just start your car up in a closed garage and see just how clean it is?:lala: just kidding,
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
FreeSpirit
Aug 29, 2015 05:47 PM
