AIR tube to cat.
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
AIR tube to cat.
When we were trying to remove my old cat, we couldnt get the AIR tube off the tube on the cat, we heated up, and tried to get it off, but to no avail, It wouldnt come off. So we cut it off. Now I'm wondering, what should I do? Can I get a new tube somewhere or can I get it repaired or something like at an exhaust shop? I'd like to keep it all emissions legal.
Transmission: 4L80E/4L80E
Get a repair kit from a parts store. It will have a length of high temperature silicone tubing and clamps so you can re-attach your tube to the new cat. That's how I attached mine 3 years ago (picked it up from Checker). The kit ain't cheap, but that's what a shop would use, and charge you twice as much to do it.
Car: '86 TransAm WS6
Transmission: Custom TH700R4
yeah, I did the same thing last fall, but I used PCV hose. I found out that the supply tube and the tube welded to the cat were the same size, and there was no way I could just clamp them together. The tube on the new Catco I installed came cut extra long, so I just trimmed the supply tube to fit.
If the counter guys at your local parts place are cool, they may just give you the 4" of hose for free, and then you just need to buy some clamps.
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
you can buy a complete air tube from the dealer. they are an exact fit and prebent and it also has the piece that the check valve screws on to. i think i payed around 30.00 for mine.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
