Header and dipstick question
Old Aug 20, 2002 | 08:49 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
In the process of getting my old manifolds off of my car i bent up the oil dipstick.... i have heard that the dipstick doesnt fit very well anyways, what do you guys with headers do about this, just use the original and just let it hang there, or does some company make a replacement to work with headers??
Old Aug 20, 2002 | 10:02 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
In my case, my block is an older one with the dipstick on the drivers side and I have Heddman full tubes, there's plenty of space for the dipstick tube, but is a little tight pulling it out cause the brake booster is right there. I guess in my experience I've never heard of anyone having a problem with this, you probably will have to remove the tube from the block before installing the headers however.
Old Aug 20, 2002 | 10:34 PM
RICHRAD's Avatar
I was looking at the same thing just tonight....Looks like it has to have the same mod as the a/c bracket...some sort of sleeve /washer were you would retain the original bolt length, but of coarse use a new bolt I assume.
Old Aug 21, 2002 | 10:58 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I did the same thing when doing my SLP header add on. I just went to GM and got a new one for $11 or so and bent it a little to work.
Mark
Old Aug 21, 2002 | 05:34 PM
TwiztedZ28's Avatar
I just bought a Lokar flexible dipstick. It fit in perfect and only cost about 30 bucks... plus it looks nice too.
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
