Y pipe very close to oil pan should should I wrap it?
Old Aug 20, 2002 | 11:42 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I just finshed up a header install (hedman's with y-pipe) The pipe is right up against the oil pan. I was thinking about wrapping it with some header wrap but then I read that header wrap can cause fires when it becomes soaked with various chemicals such as oil and being right next to the oil pan I figure there is a good chance of that. What should I do I wanted to wrap a section of the y - pipe about 18 inces long around the oil pan and below the starter. Is there anything you could suggest my headers are jet hot coated but the y - pipe is not just sparyed with high temp paint.
Old Aug 21, 2002 | 01:53 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
Stock
I have a 88 iroc with the stock Y-pipe and it sits right aginst the oil pan. I thought the same thing when I saw that(just bought the car). Wraping it might keep the oil temp. down a little, But then there's a chance it could catch fire if it gets soaked in oil or anything else.
Old Aug 21, 2002 | 12:40 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
If you're worried that the Y-Pipe will heat up your oil too much, just install an oil cooler and use Synthetic oil. I have an SLP Y-Pipe and it sits right in front of the oil pan but does not cause any problems.
Attached Thumbnails Y pipe very close to oil pan should should I wrap it?-slpypipeview.jpg
Old Aug 21, 2002 | 09:10 PM
RICHRAD's Avatar
The engines regular cooling system will only allow that oil to get so hot.....no worries there really
Old Aug 21, 2002 | 11:20 PM
THETANK's Avatar
Car: 91 rs
ok I am relieved to hear that, i have not had any problems I was just concerned about it.
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
