Hooker LTs, Mufflex ypipe, SLP catback...BIG power loss?
Old Aug 23, 2002 | 02:18 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Okay, so now I have the longtube hookers instead of the SLPs (some of you might have read my post about the angle plug heads). I was on the phone ordering the mean mufflex ypipe, and told the guy I needed to weld up my SLP catback to the end of this (4") ypipe. I bought the $25 adapter piece to neck the pipe down to fit, and the guy asked me how much power I was expecting. I told him right at or just above 500 flywheel HP, and he told me that the 3" was really going to hurt my performance. Does anyone have a guestimate as to how much power loss I will experience using my existing catback or was this simply a sales pitch to purchase their $500 catback? I plan on going to their full 4 inch setup someday of course, but for now I'm kind of stuck with what I have.
Some important mods are as follows...
355 4 bolt 2 piece rear main seal
Forged rotating assy,
Holley Stealth ram intake
Lingenfelter 58mm Throttle Body
SVO 30# injectors
Air Flow Research 195cc 68cc chamber, 10:7:1
NO EGR
Cam…lift is .560 at the valve with a 1.60 rocker which
Equals .350 lobe lift lobe sep is 110 intake centerline is 106
Degrees and duration at .050 is 224 degrees for both intake and
Hooker Super Comp Long tubes, ceramic coated
Mufflex 4” y-pipe
No cat
3in. SLP exhaust
Flowmaster 1 chamber
GM 1991 Firebird speed density wiring harness
GM ECM # 7730
150 HP wet kit nitrous
~500+HP + n2o
Old Aug 23, 2002 | 02:49 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
I think it was just a sales pitch...my friend has a 01 WS6 with a 432 ci LS1 with a 3 in cat back, and his car runs in the 10's. I don't think that you will have much of a problem. The 4" could help, but I think you will be just fine with the 3".
Old Aug 23, 2002 | 03:00 PM
JMatlock88's Avatar
Car: 1991 Formula
Great, those were my thoughts exactly! I do belive there will be a power loss involved, but not enough to justify a $500 upgrade. The horsepower per dollar ratio is not good enough to justify the swap at this point. Furthermore, your friend's 432 makes for a much bigger airpump than my 355 cubes. I plan on just turning this motor to 6-6.2K max because of the hydro rollers.
Old Aug 24, 2002 | 01:19 AM
logikal6785's Avatar
g o d damn a 432ci LS1 ? you could tow an 18-wheeler with that :sillylol:
Old Aug 24, 2002 | 05:20 PM
Dragroc's Avatar
Yeah, it has over 500 rwhp...he is taking it to the dyno soon, I'll post when he does.
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
