Cat Back Installation
Old Aug 28, 2002 | 12:32 PM
Gary's Avatar
I'm finally replacing the original exhaust system on my 87 IROC 350 with a flowmaster system. Can I easily remove the system from the cat back and put the new system on with the back tires on my ramps, or does the car need to be on a hoist?
Gary
Old Aug 28, 2002 | 01:24 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
A hoist would be easier but it can be done. One thing though, don't use ramps if possible. What you'll want to do is raise the rear of the car and put jack stands in front of the control arms. From there lower the rear end. This will drop the diff and make it easier to remove.
Have fun!
Old Aug 28, 2002 | 01:27 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I don't know that the car needs to be on a "hoist". I would say that jackstands would do you just fine. I would NOT try removing and installing a cat-back with the rear tires on a ramp. This won't allow the rear axle to hang down at all.
I'm sure someone will tell you that it can be done. And sure the Mona Lisa can be painted on a pinhead, but if you have more clearance the job will be much easier.
It's really not that bad of a job, but allow a few hours and make sure you have a Saw-zaw on hand to make a cut or two in the old pipe. A hacksaw or dremel will only make you angry.
Good choice going with Flowmaster by the way!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
