backfiring issue
Old Oct 2, 2002 | 09:42 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
backfiring issue
hello, my car constantly backfires.. its not
really the speed.. its more how much gaz you give
at times.. it also has real crappy gaz mileage..
could it be that the cat isnt good?
the muffler i have is said to be a flowmaster..
theres nothing writen on it.. and it seems to
be just an empty can..
thx for any help
Old Oct 2, 2002 | 09:47 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
usually if it backfires thru the exhaust it means a valve is hung open somewhere, thru the carb backfires are caused by timing.
Old Oct 2, 2002 | 11:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Backfire thru the exhaust can be severe exhaust leak and a lack of backpressure, or spark plug wires routed wrong.
Giving it gas sounds like an intake backfire. Could be running lean, improper choke adj, burnt plug wires, timing being off.
Old Oct 3, 2002 | 12:07 AM
Spectre's Avatar
Engine: 3.0L/183
I see
ill check that as soon as i can
thx guys !
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
