edelbrock headers w/stock cat back&cat
Old Sep 21, 2000 | 02:10 PM
bigdan17's Avatar
im going to buy the edelbrock headers for my car soon ,but dont have the money for the cat back yet .should i wait a couple weeks and get the both at the same time, or will i be all right using the stock cat bck withe the headers for a little while.i figured itll cost me 900+ for the headers cat and catback+cost to have them installed if id do at different times it would nt be as much
Old Sep 22, 2000 | 08:32 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Which car/motor combo do you have? Assuming you have a 86-92 single cat TPI car then the TES headers will slip right onto the stock 3" cat. Obviously the likely-clogged stock cat and restrictive stock cat-back will limit the power potential, but it will all fit for a time being. You will probably end up needing to weld the headers to the cat to avoid exhaust leaks in the end though, so you'll have to put up with that untill you finalize your setup.
If you have a TBI car then you're out of luck using the stock stuff. Wrong size, without some creative tubing and welding by the installer, not a short term fix since you'll want the 3" stuff anyway.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited September 22, 2000).]
Old Sep 22, 2000 | 01:15 PM
bigdan17's Avatar
yea my cars the 89 305 tpi single cat model sounds like i should just wait to get it all at once
Hotrodboba400
Dec 10, 2019 07:07 PM
mud runner
Nov 2, 2015 07:30 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
