Flowmaster of disaster!
Old Sep 28, 2000 | 04:37 PM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Well no this is not a disaster, but I'm sure once I get into it will be!
What i'm going to do with the clogged cats is cut them off and gut them! I believe this is the easiest way, unless someone can convince me to try and do it with out cutting them off!? Then I'm going to get a whole new cat back system. I was looking through the summit catalog at the flowmast cat backs and noticed the cat backs they sell have the 3 inch single outlet muffler. Is there an advantage to having the single opposed to the double? Also do they sell a double three inch outlet muffler? I'm pretty sure they do cause I've seen cars with them, but do they offer it with there catback deals?
j.wolfe
________
91 GTA
ET: 15.3@89.2mph in OD taking it easy on 190,000 mile engine!
Old Sep 28, 2000 | 05:43 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
Yes they have a duel outlet flowmaster muffler. go to www.jegs.com . go to exhaust and then mufflers and then Flowmaster replacement mufflers. It called Flowmaster 80 series. and also under cat backs they have the whole cat back system
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
Right now i have 1 glasspack right after the cat but im going to get a custom cat back from a muffler shop and a Hooker Aero Chamber Muffler
Mods: 1.6 Roller Rockers, Electric Fan
Old Sep 28, 2000 | 09:14 PM
86Trans Am's Avatar
Yea they make a full three inch system with dual outlets that are also 3 inch. Its the american thunder series and i think the part number is 17233. I have one sitting in my garage right now, to bad im at school.
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Sep 30, 2000 | 08:26 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
To hell with flowmaster. I got the Force II system(with the single outlet) and it sounds like crap and it doesn't fit very good. I was much happier with the 3" Dynomax system I had on it. IF I had to do it over again I would get the Magnaflow system (www.magnaflow.com). My buddies now all have Flowmasters on their IROC's and Z's and they all sound the same. Somebody please dare to be different.
Old Sep 30, 2000 | 09:20 PM
MrJ's Avatar
MrJ
You got the wrong one. The Force II system sucks, it is trash, it sounds hollow and metallic. I've never heard a good sounding car with a 3 chamber Flowmaster muffler. The American Thunder system, however, roars. I don't have it, but I have basically the same thing: a 2 chamber, single outlet muffler, and a 3 inch I-pipe. Mine sounds great. Not a trace of hollowness once the car has warmed up.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
Old Oct 1, 2000 | 08:02 PM
3.1 firebird's Avatar
you dont have to cut the cats off to gut them. I had a clogged cat awhile back and all I did was disconnect the cat back pipe , left the cat on the y-pipe, and just crammed an iron bar in there till the catlyist was in small enough peices to come out. It took awhile, but I finally did it. I also used a shop vac to help get the stuff out
Old Oct 1, 2000 | 08:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
To add to 3.1's advice,,, I did mine in a similar fashion except I used an 18" bore bar in an electric drill, in place of the iron bar, and went to town. It seemed a little easier while laying under the car. I guess maybe my bar didn't have a good enough point on it though, or I'm a bigger wuss than I thought
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
Old Oct 1, 2000 | 10:20 PM
RSS's Avatar
RSS
Flowmaster sucks.
Old Oct 2, 2000 | 11:31 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The flowmaster single outlet systems have always sounded like total *** to me. Too hollow and tiny or whatever.
But the dual outlet flowmasters really sound totally different. They have a hint of that sound, but are much deeper and meaner sounding.
I have that dual outlet system on my 86 IROC (single 3" inlet, dual 2 1/2" outlets though, don't think they make a dual 3" outlet one). It sounds pretty good. But I also have a Hooker aerochamber cat-back on my 87Z and prefer it over the flowmaster system by a large margin. It doesn't have any of that tiny sound, pure roaring aural beauty if you ask me. (Hooker system also has quad tips, for the same price as the flowmaster system w/ crappy turn down tips)
I had some sound files of both but the quality was laughable and did nothing to help anyone compare. I'll have to try to redo them in better quality at some point, this topic just comes up too often.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Oct 2, 2000 | 02:26 PM
MrJ's Avatar
MrJ
Actually, I find the exact opposite to be true. The single outlet Flowmasters flow better, that can't be argued. They sound better as well, a byproduct of the better flow. Deeper, with no ugly hollowness like the dual outlet mufflers. I hate the dual outlet Flowmaster sound so much that I wouldn't even own one. BTW having a cat makes all the difference, mine sounded crappy without one and great with one.
91 Trans Am WS6
5.0 TPI auto
Trans Go shiftkit
MoreMoodThatMod
Old Oct 2, 2000 | 03:48 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
I totally forgot Murt had this system on his IROC (the dual outlet flowmaster that is) and made some pretty good videos w/ sound. Mine sounds virtually identical to his on the video. Good sounding system for a flowmaster, not that typical tiny, hollow sound the single outs have.
2.4 megs worth of video for only a few seconds, but it gives some idea of the sound. There's one other one too I think under the movies section of the site.
https://www.thirdgen.org/newdesign/m.../MurtIroc1.mpg
Still gotta say I prefer the Hooker system though...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
[This message has been edited by Ray87Z (edited October 02, 2000).]
Old Oct 2, 2000 | 05:04 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
What Series Flowmaster does he have, it sounds good, and what engine??
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROC-ZTWENTYGR8 (edited October 02, 2000).]
Old Oct 2, 2000 | 10:21 PM
MrJ's Avatar
MrJ
Did you ****ing read what I just said? You totally brushed what I said aside. The reason Murt's exhaust sounded so good is because he ran a pipe in place of the cat, and ran a 3" Y-pipe in place of the stock one.. I am 100% certain that it would sound like *** with a gutted cat, and I am equally certain that a single outlet system would sound better. Must I make a ****ing sound file of my car to prove it? Looks like I will.
91 Trans Am WS6
5.0 TPI auto
Trans Go shiftkit
MoreMoodThatMod
Old Oct 2, 2000 | 11:16 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Sorry there MrJ, didn't see that post. I didn't notice a new post had been added when I went back and posted a second time. Anyway, all the single outlet systems I've heard had that patented Flowmaster sound. I'm sure if you say yours doesn't then it doesn't. Perhaps they make some different series single in/out setups?
My system sounds damn near exactly like Murts, I have the stock y-pipe, had a stock gutted cat originally, and now have another 3" catco cat like on my 87Z. I didn't notice a whole lot of difference on the car w/ the catco vs the gutted cat (but I hadn't driven it extensively for awhile to compare, little quieter, slight tone diff maybe. Not like night and day though IMO).
Murt had a 305 TPI auto BTW unless I'm mistaken. I was thinking he had the stock exhaust manifold/y-pipe setup though, beats me. He still around?
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Old Oct 2, 2000 | 11:43 PM
MrJ's Avatar
MrJ
He's still around. He drives a low 12 second Turbo T/A now. In fact, he's a friend of mine, I talk to him every day on AIM, and we meet up at the track every now and then. He had the stock manifolds on his IROC, but had a huge a$$ Y-pipe installed when he had his catback done. He said it was one of the loudest, most brutal sounding cars around with the setup he had, and it does sound tough as hell on the video. I'm surprised that you said the high flow cat didn't make much difference vs the gutted one. In my case, it completely transformed the sound so much that it sounds like a different car now. I must say I didn't like the sound at all w/ the gutted cat. Sorry I got all riled up in the last post, I was thinking you had willfully ignored me or something .
91 Trans Am WS6
5.0 TPI auto
Trans Go shiftkit
MoreMoodThatMod
Old Oct 3, 2000 | 12:15 AM
Murt TTA's Avatar
Car: 89 TTA
Engine: 3.8L turbo
Transmission: 200r4
For my setup on my Iroc, I had the stock exhaust manifolds, a bigger Y pipe installed, straight pipe, Flowmaster 2 chamber crossflow style with dual 2.5" outs into Dual 3 1/2" tips. I had an 87 Iroc with the 305 TPI, the exhaust Kicked A$$, it was real loud and real deep sounding... On my TTA I run a 3" downpipe with open exhaust most of the time, and you just can't beat that loud turbo whistle...
I would reccomend just a flowmaster muffler and having an exhaust shop do custom tips...
Hopefully I can get some new Nitto's before winter so I can get a video of my TTA burning the old ones off....
Murt
89 TTA #750
12.3@116MPH
Old Oct 3, 2000 | 12:38 AM
RSS's Avatar
RSS
I just watched your video Murt. You're crazy!!! I like it!
It looks like something I'd do. I think I'd wait for no cars to be coming though.
BTW, glasspacks sound the best.
Old Feb 20, 2003 | 02:18 PM
fbodyking's Avatar
Poorboy, how did that work out for you?
Old Feb 20, 2003 | 09:06 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Hey, I like my single outlet flowmaster. Sounds good and has the "Flowmaster" sound. Also has as deep rumble at idle.
Old Feb 20, 2003 | 10:48 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I too love the way my 80 series Flowmaster sounds (3 inch intermediate Dynomax Pipe cat back to the flowmaster)....yeah...alot of people do run them..and some people are sick of the tone that Flowmasters have...but..they are a nice muffler that is affordable..and they sound great to me......I don't go aourn ******* other brands.....I would love to have an SLP...Borla....or something...but....they are pretty pricey. I have heard some hooker exhaust systems too...and they sound really mean too...I just think it's stupid why some people would say "flowmasters suck"........
Old Feb 22, 2003 | 02:13 AM
89IRO's Avatar
***, I am so sick of hear FLOWMASTER! In my opion flowmaster sounds like crap- like a golf ball in a steel box. And someone said they all sound the same- couldn't be any more true. If you like the sound then that's fine, but come on guys, try some new stuff. There is so much out there. -89IRO
Old Feb 22, 2003 | 09:34 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Talk about an old post
Old Feb 23, 2003 | 03:41 PM
89IRO's Avatar
Started in 9-28-2000, tell me about it.
Old Feb 23, 2003 | 08:55 PM
MelloYello's Avatar
Do what I did...I bought the Force II, sold the muffler for $80 and bought a 40 series race muffler. I had the 80 series and it sounded hollow (and like ALL other F-bodies), but believe me when I say that the 40 series race muffler kicks A$$!!! I run Edelbrock shorty headers, y-pipe, and converter test pipe along with this catback system and I ALWAYS get compliments on the sound. Plus, I like the way the single turn-down tucks up under the bumper for that stealth look.
IMO, this is the only way to go without going full-out custom
92camaro350cci
Oct 14, 2015 09:29 AM
Night rider327
Oct 9, 2015 09:25 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 05:33 PM
89fast5oh
Sep 8, 2015 09:55 AM
