attn anyone with slp headers!!
Old Oct 16, 2002 | 10:36 PM
19WS6T/A91's Avatar
hello i just got my headers and install kit in today. i have the dual cat 1 3/4" setup. i was just wondering what the purpose of the "heat shield hoses" is. and where do these go?
thanks,
David
Old Oct 17, 2002 | 06:57 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The only hoses I got with my install kit was the AIR hoses. My only guess is that its used where the AIR tube connects to the cats on your car.
Old Oct 17, 2002 | 07:37 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Are you talking about the red fiberglass heat resistant tubing that's about 4 to 5 inches long? If so, it's there for you to put you O2 sensor wire through. The kit should have come with an extension wire and this tubing.
Hope that helps.
Old Oct 17, 2002 | 01:02 PM
19WS6T/A91's Avatar
that is the hose that i am talking about (the red one) i have two of them, and they didnt send me an extra piece of wire.
Old Oct 18, 2002 | 09:10 PM
19WS6T/A91's Avatar
i know that somebody knows what this piece is for.
thanks,
David
Old Oct 19, 2002 | 08:53 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Hey bud,
Craz-z28 was right. The red fiberglass tubes are heat shields for wires that will be in close proximity to the headers. The shields will prevent your wires from melting (or at least reduce the risk!). I put the same kit on my GTA with dual cats. I used one of the sleeves for the O2 sensor wire and one on the other side for the secondary fan switch wire.
The O2 sensor is a bit further back on the SLPs than stock. The stock O2 sensor wire will work but I had to route it a bit differently (i think along the block). It is not that big of a deal. If you get stuck, PM me and I can help out with pics, description, etc..
BTW - Did you get them coated? I would highly recommend getting them coated. You payed good money for them - take the extra step. You won't regret it.
-Schultzy
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
