headers won't fit
Old Oct 8, 2000 | 09:57 PM
chicksL69's Avatar
headers won't fit
Hi, I have an 84' z28 that I just recently took out the l69 305HO and put in a machined 327. I have headers that are made for my camaro, they fit on there before, HOWEVER, I have a 7 qt. oil pan now and it gets wider at the botton of the pan, allowing one of my headers to run right into it. What can I use for headers????? I NEED them, or else all the money I spent on machine work 4000$ plus, will be down the drain because the engine will be choked out. please help, thank you
Old Oct 8, 2000 | 11:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Put a smaller oil pan on or get a custom set of headers fabricated. Header manufacturers design the headers to work with stock components. Unless they specify that the headers will work in special applications, then they won't.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 9, 2000 | 10:05 AM
chicksL69's Avatar
Are their any kind of store bought headers that I can attach though?? like some shorty ones?? I have shorties already, but they are made to simulate the y-pipe, so one side goes straight back(what I want) but the other side curves into my pan. I want both headers to go straight back, but not too far, because full length headers will come too close to my tranny. So, are there any shorty headers that will go straight back? Can I use blockhuggers, or will they hit the engine mounts?? thank you for your help.
Old Oct 9, 2000 | 09:05 PM
chicksL69's Avatar
Will someone PLEASE answer my questions, my car has been sitting on jackstands for about 2 months now, I miss it. I'm in college, and did an engine swap over the summer, and ever since then I hav'nt had my car because NOTHING FITS!! So all the help I can get would be appreciated, thank you.
Old Oct 11, 2000 | 09:19 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Personally I would just put a smaller oil pan on. It's cheaper than buying another set of headers that probably won't fit.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Oct 11, 2000 | 09:20 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I agree, switching to a smaller oil pan would probably be easier than modifying a set of headers to fit. Of course, you could try calling the oil pan manufacturer, and see if they can recommend a set of headers that would work with their oil pan.
Old Oct 12, 2000 | 05:16 AM
88IROCs's Avatar
I'd agree with the comments regarding swapping the pan. 7 quarts sounds like a lot of oil for your motor, and that much fluid will probably cause some oil control problems(excess splashing and roping, etc.,...)
If you absolutely must keep the pan, call <a href="http://www.headersbyed.com/">"Headers by Ed"</a>(612 729 - 2802, Minneapolis). They should be able to modify your present headers to fit.
He who hesitates,... is lost!
Street Lethal
Apr 30, 2019 12:14 PM
Wvcamaro
Sep 4, 2015 08:38 PM
LilHot
Aug 23, 2015 09:36 PM
theurge
Aug 21, 2015 12:46 PM
slade5612
Aug 11, 2015 07:19 PM
