Header Question
Old Oct 16, 2000 | 02:23 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Header Question
I was thinking about putting headers on my 92 RS-LO3 and the owner of a local performance shop didn't recommend them. He said that you wouldn't notice much difference unless you have a true dual exhaust. I know there are plenty of you out there that have done this mod. Are there any noticable gains from doing this? I already have a Flowmaster cat-back installed. Would there still be an improvement in sound? All opinions are welcome.
Old Oct 16, 2000 | 03:21 PM
SeanSullivan's Avatar
In my opinion, yes there would be a slight improvement. Throttle response will be slightly better as well. I have a set of Hooker shorty headers now, am very happy with them. I did have to fabricate a new Y pipe however. All of this is on a 92 RS 305 w/TBI.
Old Oct 17, 2000 | 04:29 AM
88IROCs's Avatar
You won't see huge gains, but there will be some improvement. Expect around 10 extra ponies. More importantly, remember that the exhaust is the last link in the airflow chain. The more efficiently you can expel the exhaust, the more air you can put into the cylinders. This will improve the gains you see from mods on the intake side(intake and camshaft/valvetrain). Replacing the exhaust can be a fairly expensive proposition, but considering the effect it has on your other mods, it is worth it to do it right.
Go to another "performance shop" and find someone who knows what they are talking about. Headers will have more of an impact than this guy gives them credit for.
He who hesitates,... is lost!
Old Oct 17, 2000 | 08:16 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've had great results from my exhaust upgrade. I'm currently using Edelbrock TES 6872,no cat and an SLP 3" catback. This same setup was used on my brother's 91 Formula and we both agreed that the change was dramatic on his otherwise stock car. Just don't use the 6875 TBI headers unless you have to. The y pipe is 2.25" diameter.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Old Oct 17, 2000 | 05:58 PM
Dan87IROC-Z's Avatar
I have to dissagree with what the guy told you. The headers are the best mod I have done by far. I would strongly suggest them, they are good for at the very least .3 off your 1/4 time.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 17, 2000 | 08:47 PM
Birmass's Avatar
There will be an increase in gas mileage too!! They say from 5-10% in some cases.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
