15/8 Or 11/2 Headers
Old Oct 19, 2002 | 07:06 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
I have a 1984 lg4 305 I may later put in a 350 sb. Which size or sizes is best for each displacement? Is it a difference of onlly RPM ranges or more so than that?
Old Oct 20, 2002 | 07:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I see you asking all sorts of exhaust questions, and it looks like you're going to swap the entire system, from heads to street (headers, cat, & cat-back). This is the perfect thing to do, since it is exactly what the LG4 needs before you even try to do anything else to it to speed it up.
That said, you have the perfect oportunity to get rid of the single biggest restriction it has, which is the tiny little Y-pipe. DO NOT get any piece whatsoever that will bolt to existing LG4 systems!!!! Doing so will preserve that bottleneck. Get the entire system, but for some other car; either the whole L69 (HO) version, or the TPI one, for something like a 88 350. All of them will fit your car as an assembly, but none of the better ones will interchange at all with the LG4 stuff, because the LG4 has that drinking straw sized part. Again, DO NOT buy ANYTHING that the mfr says will fit LG4, except possibly the cat-back, since those are somewhat more universal.
Get the whole exhaust for whatever you decide on, complete. That's headers, cat, & cat-back. Get application-specific headers such as SLP, Dynomax, or Edelbrock, not "universal" ones; the direct-fit Catco cats from Summit or wherever are a good deal; and your choice of cat back from Hooker, SLP, Edelbrock, Dynomax, Blowmaster ,etc. etc. according to your taste and budget. You'll end up spending so much at the exhaust shop on making "universal" stuff fit, that the initial sticker price of the direct-fit stuff will actually be cheaper in the long run, because you can do it yourself.
Old Oct 20, 2002 | 11:43 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
There's not going to be a noticeable difference between 1 5/8" and 1 1/2" OD headers. There is some tuning effect to the diameter but it is somewhat overrated, especially in the case of a small-block chevy in an F-body.
Spend as much money as you can afford on good quality components. I have Flow Techs and they are terrible, several pinholes in the welds right out of the box. Inspect the headers for potential leaks before you drop any money on them.
I know the $$ SLP stainless headers are good, the Edelbrocks are generally good quality - can't say about others. There was no quality control taking place on the Flow Techs that I bought.
Old Oct 20, 2002 | 01:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I have a set of FlowTechs from before they were bought by Holley and they're just fine.
Old Oct 26, 2002 | 05:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get some Hooker headers, Hooker cat-back.
Get some 1 5/8th headers unless you plan on building a decent 350 in the future. Right now I'm selling my Edelbrock headers 1 5/8th to get some 1 3/4 for my upcoming setup.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
