Lock nuts needed for headers?
Old Oct 12, 2000 | 07:38 PM
wa90formula350's Avatar
Will be installing SLP headers in the next couple weeks was wondering if I need the Stage 8 locking header bolts? Have been told headers will loosen up and leak. Will regular lock washers work? I only want to do it once.
1990 Formula 350
Old Oct 13, 2000 | 03:30 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Yes, header bolts like to losen up and create exhaust leaks. The Stage 8 bolts are the best way to go. Lock washer could work btu the trouble is you'll never be able to get them on. The clearance between the bolts and header tubes is too tight.
The best thing to do after you install your headers (with the Stage 8 bolts) is drive around for a few days, then re-tighten all the bolts. At that point I'd install the locking clips.
Old Oct 14, 2000 | 08:21 PM
Thanks BretD, I'll do that along with new motor mounts just to eliminate another potential problem.
Old Oct 19, 2000 | 02:44 PM
WARDO's Avatar
The right size lock washers will work fine, I used them on mine and have not had a bolt loosen up in 8 months.
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
