brand new headers and gaskets blown out in 2 days? HELP!!
Old Oct 25, 2000 | 11:48 PM
hookin88formula's Avatar
just but a brand new system on my car yesterday. the collector gaskets i got were the copper ones. the parts store said that they were the best that u can get.. so what is the deal why would they blow out already? i hate the sound that it makes. sounds like an old beater. all i hear is phh phh phh when i take off thanks for the help....
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Oct 26, 2000 | 02:47 AM
anyone? someone here has to know!! help please!!
Old Oct 26, 2000 | 02:52 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ive heard you need to wet the gaskets first, then tighten bolts, then drive on it then tighten, then drive, and tighten etc for a total of like 4 times. Fel-Pro gaskets?? Mr.Gasket??
Old Oct 26, 2000 | 08:31 AM
the header gaskets are mr gasket ultra seals and the collector gaskets are copper ones made my i think sce or something like that.
Old Oct 26, 2000 | 04:31 PM
ChrisR's Avatar
I have the same problem. I used the crappy felt ones that came with the headers. I HATE that putting sound, it takes away from the car, iand i think it might hurt performance. If anyone has any "secret" to curing this, it would be cool of ya!
Old Oct 26, 2000 | 04:54 PM
Ehelmsin's Avatar
This happened on my friend's car. The header/block gasket blew out 2 days after he bought it. It turns out that his headers were warped and not making a good enough seal which caused the seal to blow out easy. (we used the type of seal right below copper seals, but they still blew out) I hope this helps. (We put on new headers 2 weeks ago and no problems yet.)
Old Oct 26, 2000 | 05:45 PM
92B4C3051LE's Avatar
Here you go guys!
Go get some threaded rod and cut 6 pieces long enough to make studs for the collectors. You will also need 6-locknuts and 6-washers, or 6-lockwashers, 6-washers, and 6-nuts. If you use the felpro felt gasket get a can of red high tack spray goo. Sopray the gaskets on both sides and let sit until almost dry. Now put everything together, but be sure not to tighten one of the three bolts down too tigh. Spread out the torquing of the bolts evenly.
As far as the copper gaskets go, if you tighten them down too far then you probably have ruined the gaskets, and maybe the flanges of the headers. It is vital to retorque like the gentlemen before said to the appropriate specs.
Also using studs instead of bolts with the extra washers will also help spread the load out evenly on the header flange!
1992 Texas DPS B4C 1LE FE2 5.0/5spd:
Intake and Plenum Ported
Fully Ported Corvette Heads
TPIS Tricks ,No Smog Pump, NOS FI Fuel Pump
K&N's Adj. Fuel Pressure Regulator
Alston SFC's, Energy Supension Hyperflex system
MSD 6AL, SLP 1 3/4" SS Headers
3.73's with 275/55/16's out back...blew those now 2.73 one legger
My complete back seat
encompases my RF tunes...
Currie 9" on the way with 3.70 gears
Adam
[This message has been edited by 92B4C3051LE (edited October 26, 2000).]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
mdtoren
Aug 16, 2015 05:45 PM
