header installation.
Old Nov 7, 2000 | 02:01 PM
jm91rs's Avatar
OK i really don't know much about my car, but i want it to be louder. I would like to get headers, but how hard are they to install? If i buy headers, do i need a new y-pipe (i think that is what it is called). Do I need to buy a whole cat-back system then? Is it possible to use the rest of my exhaust, just get headers for now. I have a borla muffler with (i think) the stock everything else, so i would want to keep everything else normal for now.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood
Old Nov 7, 2000 | 04:50 PM
86Trans Am's Avatar
My slp's were simple to install, the first major mod i've performed.
yes, i believe so
no
yes
any other quesitons, email me
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Nov 7, 2000 | 05:46 PM
wa90formula350's Avatar
It could be a real pain depends on what equipment you have, you may need to buy new motor and tranny mounts, SLP recommends them, you then need to get the engine up high enough to get the motor mounts out and in. You'll need a cherry picker? to do it. Do not do as I did and jack it up under the oil pan now the crank hits the pan and if I cant pull it back out I'll have to get the cherry picker anyway to put in a new pan. My SLP headers came with a new Y pipe, I test fitted everything but in the process of welding in new high flow cats the dimensions changed and now the cats sit to low to the ground. I'll have to make some more adjustments to it. It was alot of work and I hav'nt finished yet so cant enjoy it yet to tell ya if it was worth it. Make sure you do it right. If you have more Q's you can contact me direct, my email is in my profile, or I'll check back here.
Rob
1990 Formula 350
Old Nov 7, 2000 | 08:10 PM
billyde's Avatar
If you want your car to sound good right off the bat, consider the SLP cat back setup. It's something your could get installed in a few hours and be cruising to a throaty sound that evening. I got mine in without any problems as it's a direct bolt up. The hardest part is getting the old exhaust off. It is conterproductive in my opionion to get the headers with such a restrictive back end to the stock exhaust, mainly the restrictive catalytic converter and small diameter pipe and muffler. The SLP headers are next on my list. Good luck
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
