Sick of exhaust popping!
Old Nov 3, 2000 | 10:48 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
I have a set of SLP 1 5/8" headers, no cat, 3" all the way, and a Dynomax Super Turbo muffler. When I rev it then let up, it pops, and I hate it. any ideas on how to make it stop? I think it's just the muffler, any opinions?
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Nov 4, 2000 | 10:55 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
anyone, anyone? Bueler?
1992 RS
Old Nov 4, 2000 | 11:42 PM
Novaguy76's Avatar
That is a common problem but you usually find it with Borla exhaust. What it is, is the fact that your exhaust flows to well and when you let off the gas it sucks air back in. sence your system is not adjustable about the only things you can do are put a cat back on it or put a more restrictive muffler on it. I know I would hate to think of putting a restriction in my exhaust but you will find that the car will run better that way. A street motor needs a little back pressure to run at its best. That is why a LT1 car with Borla exhaust runs best with the next to the largest restrictor plate in instead of just being open, when they are open they breath back real bad but when the plate is in they don't. If you have a carborated car you might want to step up a couple of jet sizes or if you have a fuel injected car you might bump up the fuel pressure or step up on your injector size, this might help also.
Old Nov 5, 2000 | 03:41 PM
Blown355Camaro's Avatar
I think just about every Thirdgen Camaro without cats backfires when reved up.
Old Nov 5, 2000 | 03:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not mine.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Nov 6, 2000 | 11:14 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
I think I'm going to replace the muffler anyway, it makes too much of a baffel sound that I don't like. I'd go with a Flow Master if everyone didn't already have one.
1992 RS
Old Nov 6, 2000 | 11:28 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Everyone has a Flowmaster for a reason though, just my $.02.
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Nov 6, 2000 | 12:44 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I wouldnt go with a flowmaster!! I have a 80 series muffler and 2.5" pipe, and it pops like crazy after I rev it up. I am going with a Hooker cat back in the spring. Take my word, dont buy a Flowmaster!!
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 3" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Old Nov 6, 2000 | 08:18 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
My car does the same thing, it only started doing it after I put the 350, my 305 never did it and I have the same exact exaust set up. I tried putting a cat on it and it still does it. My car does not do it when you rev it only when you are decellrating while driving. I HATE IT!!!!!!!!
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 7, 2000 | 10:29 PM
My old 350 never did it with my Flowmaster but my buddies sounds like he has a freaking "watermaster" on his.. Hope this motor dont do that same ****, ill be pissed.
H00SiER DADDY
Supercharged 1985 Camaro TH350 9 bolt 3.23
1986 351 C4 Ford 9" Mustang Coupe
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
earlpote
Sep 12, 2015 11:55 AM
Randomtask2
Sep 10, 2015 08:37 AM
89fast5oh
Sep 8, 2015 09:55 AM
