What kind of Headers on a ZZ Block?
Old Dec 1, 2000 | 06:19 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I am going with the ZZ5 w/ the 1.6 rockers and LT4 Hot Cam, wondering what kind of headers u guys think I should run or if u have a ZZ4 or ZZ5 what are kind of headers are u running on it? I thought about 1-3/4" SLP Headers. Would they work and what is the part number if ya got it handy?
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Dec 2, 2000 | 11:14 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, definitely the SLP 1 3/4", you'll need the extra airflow. Check out http://www.slponline.com/ for the part numbers.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 2, 2000 | 01:33 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Sweet, thanks, I figured on going with SLP, I just wanted to make sure someone out there with a ZZ block made sure they fit. Thanks.
Eric Natzke
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Dec 2, 2000 | 03:18 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
the block has nothing to do with headers, the heads are L98 vette heads and those are what the headers bolt up to. I will second the 1 3/4 inchers.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Dec 2, 2000 | 06:48 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well I know the SLP's come with a y-pipe and I wanted to make sure that everything would fit around the pan and all. So in a way it does.
Old Dec 2, 2000 | 09:46 PM
CamaroMike's Avatar
The fast burn heads have raised exhaust ports and the oil pan on the ZZ engines are deeper to clear the windage tray!!!!!!!!!!!!! Watch for y-pipe clearance on the oil pan! I have a ZZ4 with Edelbrock headers and y-pipe and I had to bend the y-pipe with a big *** bar to get oil pan clearance. That's not to mention the ZZ5 with raised exhaust ports. I have no experience with the fast burn heads and headers but this is the exact reason I will not buy the fast burn heads. I am afraid of worse clearance problems. Let me know if they work for you!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified CHEVY DEALER Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
[This message has been edited by CamaroMike (edited December 02, 2000).]
Old Dec 4, 2000 | 02:13 AM
Kevin91Z's Avatar
Did you see the GP on SLP headers? https://www.thirdgen.org/messgboard/...ML/000494.html
Old Dec 4, 2000 | 08:50 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Man, I wish I had the money on me right now for that. This sucks. What great timing.
Eric Natzke
italiano67
Dec 11, 2016 09:21 AM
billybob6110
Sep 24, 2016 09:50 AM
evilstuie
Feb 28, 2016 03:33 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
