Hooker And Edelbrock 50 State Legal Header. ??s (SLP to expensive not gonna bother)
Old Dec 17, 2000 | 07:27 PM
Stell1579's Avatar
I am looking for a set of headers. now i realy just want the better flow that the headers will give over the manifolds. i also donot want to make a dayjob out of changing sparkplugs. the car is a daily driver and i will be getting a se of MSD 8.5 wires with 90* boots that yo umake yourself when i do the header job.
now i saw the TES headers and heard alot of good about them i just dont like the look they have on the pasanger side. it looks like i will be baking ignition wires and have a tight sparkplug fit.
now i saw the set of headers that car craft used on their 91 305tpi camaro when they first put the supercharger on it. they show a picture and part number of the headers they used. the picture has the pasanger side header shown and it looks very good, looks like a good sparplug/wire fit.
now my eyes are set on the hooker ones. for $$ 350.00 from summit. my question is wich of these two would be better and i do the hooker headers need anythign special besides what is suplied when yo ubuy them (will the stock cat slip on? maby new engine mounts? stering colum and brake lines in the way?
will i need a smaller starter and/or will the headers cook the starter?)
the part numbers for the 2 are
tes -6872
hooker - 2055
thanks
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Dec 17, 2000 | 08:47 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I have those Hooker headers on my '87 IROC and they fit great. They're a better design than the Edelbrocks since all of the primary tubes are 1 5/8" diameter, the Y-pipe has 2 1/2" tubes going to the 3" slip-fit connection at the cat. Stock cat might need to be widened a little where it slips over the Y-pipe, but nothing else special is needed.
I didn't have any interference with anything else; didn't even need to jack up the engine to get them in. I did need to modify the A/C bracket, but since you have the serpentine belt setup, you won't need to. Stock starter fits since and mine's been running great for over 2 years.
Getting the 90-degree boot spark plug wires is a great idea since you'd burn the wires with straight boots like I did (put old wires on before the new ones came). Spark plus access is -much- better than with the stock manifolds, although having a very short spark plug socket or slotting one so you can slip it on from the side is a must for a couple of the plugs. I bought SLP's shorty socket for $20, but I think it's better to slot an existing one that's the original length...
Greg Westphal
'87 IROC 305TPI/A4
Old Dec 17, 2000 | 09:03 PM
Dan87IROC-Z's Avatar
I am VERY happy with my TES headers, the right side is a tight fit, but my custom 8.8mm Accel wires fit just fine so long as I routed them creatively. The headers are for sure the best mod I have done.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 17, 2000 | 09:44 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i would go with the hookers. u can get em for cheaper from IRS http://www.racenet.net/ i think they are under 200...depending on ifyou want air or not. goo dluck
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Hotrodboba400
Dec 10, 2019 07:07 PM
Zane Story
Oct 8, 2015 12:40 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
