Guys with LT's look inside
Old Nov 12, 2002 | 03:46 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Could you just do me a favor and list what brand (Hooker or Hedman), What brand and type of head, when I say type I mean straight, angle, etc etc., and what spark plug you are using. thanks
Shawn
Old Nov 12, 2002 | 05:10 PM
Fast3rdGen's Avatar
hooker long tubes, world sportsman II angled plug heads with delco plugs
Old Nov 12, 2002 | 06:38 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Hooker LTs (2210) with AFR190 "L98 Angle" plug and Autolite 3293 plugs.
Tim
Old Nov 12, 2002 | 10:53 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hooker 1 3/4" Long tubes (coated 2210's) - Vortec heads (straight plug) - NGK-R spark plugs.
Old Nov 13, 2002 | 05:18 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Do you guys have good spark plug clearance?
1bad91Z, you are the only one so far with straight plug heads. Did you have a problem with the number 7 cylinder? Are those plugs you have shorty plugs?
Old Nov 13, 2002 | 09:07 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
NGK plugs are standard length plugs. On the stock L98 heads with LT's, there were NO issues what so ever. With the vortec heads, #7 is very close and the #7 primary will have to be dimpled or I will have to go with shorty plugs to keep the plug wire boot from getting warm. (Either way, it's no big deal)!
Old Nov 13, 2002 | 11:13 PM
TBI305Camaro's Avatar
Hedman longtubes on stock LO5 heads with straight plugs. Running Accel header plugs with plenty of room for a normal plug.
very good spark plug clearance with these headers and a very easy install actually.
Old Nov 14, 2002 | 05:17 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
MAn looks like it sucks to have my combo then. THe number 7 plug there is not even enough room there to put the boot on. I would have to dimple it alot to get it to fit. that sux.
Old Nov 14, 2002 | 07:54 AM
there is tons of room with the hedman headers...i had hooker shorties and the clearance was less but I could run the accel header plugs pretty easy
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
