Exhaust????????
Old Nov 13, 2002 | 06:28 PM
wrestlerman119's Avatar
Exhaust????????
What is the loudest system for a 90-92 camaro, is there any company that makes a true dual exhaust, and are there any header exaust combos that really click, Thanks
Old Nov 13, 2002 | 06:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Best thing I can say is do a search for sound clips.
Mine is in the sig. that's with near stock 350 8.5:1 compression, crappy cam, and a cat.
You can make your own dual exhaust, but really isn't necessary if you have like an L03 or LB9. do a search for that too. and look for fast3rdgen's post.
Old Nov 13, 2002 | 11:30 PM
TBI305Camaro's Avatar
Yeah you can do duals if you want to with longtube headers. I did and I like it alot. Sounds mean as hell. If you go duals you better get some new suspension to keep it from hitting the ground when you go over little dips.
Old Nov 17, 2002 | 01:11 AM
elcamaro's Avatar
Car: 1984 Z28
Engine: 350 bored .030 over
Transmission: T-5 5-speed
I got manifolds to 3-inch piping to glasspacks. I think my glasspacks are like 16 inches, but the shorter the better. I easily set of car alarms at 3500rpm. I also got the bigger cam which helps out though. Best of luck to yah.
Old Nov 17, 2002 | 12:44 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If you want an loud, agressive exhaust that says "Get the **** outta my way" Go with the flowmaster american thunder system
Old Nov 17, 2002 | 06:53 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I have Hooker longtubes with duals straight down ending with two Flowmaster 1-chambers.It's loud,but the intake combo,especially the cam,makes it sound very mean.
Old Nov 20, 2002 | 06:01 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
If you want a pretty loud setup that doesn't sound like most, I'd go with the Edelbrock RPM catback....The flowmaster American Thunder Catback is the loudest, but is more expensive. I'm gonna get the Edelbrock system on my car.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
