What is the performance purpose of Y pipes REALLY!!!
Old Jan 24, 2001 | 02:27 PM
big tex's Avatar
Sorry guys,
I'm new here and have been posting a lot. I have always subscribed to car mags, but this is my first really cool car that I could do something with. So, what does a y pipe do really? Thanks, big tex
Old Jan 24, 2001 | 02:31 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
it goes from the ends of your manifolds or headers and Y's it from 2 pipes into one before it gets to your cat. because true dual exhaust (one pipe going to its own cat and muffler per exhaust manifold/header) is impossible to put underneith our cars without lifting them up or screwing with banging up floorboards on the driver side, etc....
its just a y pipe like it says, stock ones are small. if you get a bigger one your exhaust will flow free-er.
Old Jan 24, 2001 | 04:53 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I've seen non-screwy dual exhaust on a thirdgen, it wouldn't be easy to run, but I've seen it. The pipes followed the path of the stock exhaust, they were right next to each other. Somebody on here had posted pictures of it...pretty trick setup. Search for dual exhaust and you might find it.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jan 25, 2001 | 05:12 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah but if i remember right, that dual exhaust was like show-car quality...there were a lot of chages made to teh car. i dont think it is really that functional on teh street. i could be wring though, but thats what i remembered.
a friend of mine has duals that he put on his '86. it ws ok, but he dumped it in front of the axle.
yeah true duals is cool and everything, but unless you ahve some serious motor i dont think its necessary. i think a single 3" flows as much as dual 2.25"s or somthing. who knows.
but, i can tell you, if there was an easy way to do it, i would do it in a minute.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, March Unerdrive Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Jan 25, 2001 | 05:36 PM
chevyboy07 91's Avatar
with glasspacks you can do it easy. One running behind a little behind the cat, and the other turned sideways/oriented the same way as our stock exhaust.
Old Jan 25, 2001 | 05:37 PM
that is..........bringing the driver side pipe to the passenger side and running them parallel
Linson
Sep 21, 2015 01:08 PM
Camaro_383
Sep 11, 2015 11:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
