Edelbrock catback ground clearance
Old Feb 13, 2001 | 12:30 AM
Baron's Avatar
Just got my catback in...it's awfully close to the ground...anybody have any insights? Was it done wrong, or is it close enough to the rear axle to not be a problem?
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Old Feb 13, 2001 | 09:28 AM
Drew's Avatar
Make sure its all aligned properly. Its somewhat typical for them to hang down a bit. As much as I like mine the quality is kinda ****ty, the tailpipes don't line up centered on the back of the car, it hangs a bit low, and we had to cut and bend the junction in the middle of the intermediate pipe to get the smaller tube to telescope into the larger. I think Edelbrock needs to check their hardware and correct any problems, it would also be nice if their instructions gave more info on getting it all lined up rather than just a photocopied sheet of paper with a picture or two.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6FOR SALE!
92 S10FOR SALE!
98 Grand Am GT
Old Feb 13, 2001 | 06:46 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I have a cat back for a 305 tpi. MIne is for single converer. I think ours are pretty much the same.
Mine hung low too. what i did is cut about 2-3 inches (I don't remember) off the intermediate pipe on the axle side. By doing this the intermediate pipe would slide further up into the pipe that goes over the axle.
This really helped ground clearance. Another thing to check is where it is low. If it low by the cat, then this may not work.
You have TES headers right. If it is low by the cat then you can loosen the header-to-y pipe bolts and kinda tilt the whole thing forward to raise the cat side.-just a thought.
And finally (gasp),if the allignment of the tailpipes isn't straight, i have found that by playing with the connection of the intermediate pipe to the over-axle pipe,
twisting them in either direction changes the angle at which the muffler sits.
Do you have any idea where we can get more donut seals for the y pipe? mine are old and leak bad!
good luck man
'88 RS (originally 2.8)
New 350, .040 over, ported vette L98s, ported stock tpi.
Old 305 injectors & chip
TES headers, 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-yet to race
(Damn the 2.8!)
Old Feb 14, 2001 | 12:37 AM
Baron's Avatar
Thanks for all the ideas, man...I'm gonna have my mechanic do what he thinks...I'm tired of messing with it. About donut gaskets: if you used the ones that came with the system, depending on how long they've been on there, it may be a serious pain getting them off, as they may have melted and fused on over time. If you do in fact get them off, score some dead-soft type collector gaskets at a parts store or Summit. Mine were like $15 or so...they'll never leak, and they're reusable. Hope I helped...you sure did. Thanks again!
Catco cat
Pioneer DEH-P77
Coming:
KYB shocks
Hotrodboba400
Dec 10, 2019 07:07 PM
Logan Bryant
Sep 18, 2016 09:27 AM
toronto formula
Sep 10, 2015 07:31 AM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
