Header install question
I have a 350 in an 82 camaro. It has the old style v-belt system with the A/C compressor on the driver's side. It looks like part of the A/C bracket is attached to the exhaust or goes over the front of it. I plan on getting long tube Hooker Super Comps in the future. Will I need to modify this bracket to get them to fit )looks pretty likely) and if so, what needs to be done. I feel fairly confident in my ability to grind, cut, fabricate... so let me know. Thanks.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
