Hedman Headers Question
Old Feb 18, 2001 | 12:24 AM
CamaroX84's Avatar
In the Jeg's catalog, part number 500-68481 82-92 Camaro Hedman shorty headers with y-pipe, is it three inch going onto the cat at the end of the pipe? Are these nice headers? Thanks.
Old Feb 18, 2001 | 12:59 AM
Superblue87Formula's Avatar
the headers have 3" collectors, but the y-pipe reduces to 2 1/2" .. it comes with a 2.5-3" adapter to fit to a 3" cat. I have the headers and y-pipe now, but I'm getting rid of them to go full length, I had them about a year they're very nice, can't beat em for the price. Don't forget you will need to weld in an 02 sensor fitting for a fuel injection setup.
Old Feb 18, 2001 | 05:50 PM
BP89IROC's Avatar
the collectors are three inch and they reduce down to 2 1\4 and the two come together into a 2 1\2 inch pipe and it comes with a 2 1/2 to 3" adapter.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, stock other than that.
Old Feb 18, 2001 | 08:20 PM
CamaroX84's Avatar
So is it worth the extra 40 bucks to go with the Hooker shorty headers with the y-pipe? That is three inch all the way through the y-pipe to the end, right? Thanks.
Old Feb 20, 2001 | 01:51 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Yes, it's well worth getting the Hooker headers. They have the O2 sensor fitting already welded in and the Y-pipe is 3" from the dual 2 1/2" pipes to the cat. They're fully emissions-legal and dropped right in with no welding and I didn't even have to jack up the engine.
Greg Westphal
'87 IROC 305TPI/A4
Old Feb 20, 2001 | 02:14 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Are either the Hedman or the Hooker Headers considered to have equal length primaries? Any reports on which set produces better power gains. I think you can get them without the AIR inlet. I removed the smog pump on mine & I think I could still pass emmissions with a high flow cat. I also have an off road pipe that I made. Im going to set it up so I can switch them If I need to.
What would I need to run long tube headers on my 305 LO3 TBI? Do long tube headers have much of an edge in toruqe or HP gains?
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
12 PSI Fuel Pressure
6* Timing Advance
MSD Coil And Wires
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock RPM Muffler
No Cat/No AIR Injection
B&M Stage 2 Shift Kit
17"x8.5" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Control Arms
Lakewood Pan Hard Rod
Coming Soon:
Hedman Headers & Y Pipe
12 Bolt With 3.73 Gears
NOS System
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
