I failed passing the NOX test what is the best quick fix or what can i tamper to pass
Old Feb 20, 2001 | 07:47 AM
Ravivo's Avatar
Old Feb 20, 2001 | 11:47 AM
The ODB's Avatar
how could anyone possibly give you good advice when we don't even know what you drive?
ODB
Old Feb 20, 2001 | 12:59 PM
Ravivo's Avatar
oldmobile 83 model delta 88
5.0L
Old Feb 20, 2001 | 06:14 PM
JETHROIROC's Avatar
You can either run rich or very lean to reduce your NOx output. However, your HC and CO output will be impacted accordingly. Probably best to have the EGR system fixed.
Old Feb 20, 2001 | 06:37 PM
The ODB's Avatar
Running EGR at idle and light load part throttle will reduce the NOX.
If if was me I would run very lean with a bit less spark advance to pass the test.
You can get away with leaner mixtures by doing several things.
1. run your car hotter.
2. run very tight plug gaps & new plugs.
3. run warmer air into your carb/throttle body, AND increase your EGR.
4. get rid of the PCV
5. increase your exhaust backpressure
there are other ways, but that is more than enough.
good luck
ODB
Old Feb 21, 2001 | 09:55 PM
JoeIROC's Avatar
I had the same problem last summer. What I hadn't realized was that i had stored codes. So check to see if you have any codes stored on the chip. Most codes have to do with the emissions (at least in camaros). All I ended up doing was replacing an in-line fuse for about 25 cents, and i passed inspection. (The EGR soleniod was not getting power.)
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Next mod = trans-go shift kit (level 1)
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Cacike
Aug 27, 2015 05:10 PM
TheJoeY88
Aug 13, 2015 06:51 PM
