How do i do a vacume test ?
Old Feb 23, 2001 | 06:35 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
How can i do a vacume test to see if there is restiction in my exhaust ? also another quickie, about how much horespower am i looking at if i put on some aftermarket exhaust headers on a stock 91 tpi 5.7L ???
Old Feb 23, 2001 | 11:04 PM
The ODB's Avatar
the metal air tube that runs to your catalytic converter..
unscrew the valve off the end and put a fitting or coupling on so you can run a hose inside the car to a sensitive liquid filled pressure gauge. Once you get your numbers take the gauge back off and hook the tube up as before.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
