True Duals w/ X-PIPE
Old Dec 2, 2002 | 10:40 PM
my88IrocZ's Avatar
First of all does anyone have sound clips of true duals or know where I can get a sound clip? Anyway I have hooker supercomp. long tube headers and I want to run true duals with an x-pipe and dumpoffs before the axle, is this possible do you think? I do not care about ground clearence, just want to know if it would work.
Old Dec 2, 2002 | 10:51 PM
TBI305Camaro's Avatar
Get a set of the hedman S extentions. Run those and then the X pipe. I have mine setup like that but with a H pipe instead (much much cheaper)
Run that then some more pipe then to the mufflers. Bolted underneath the floor pan...what I did. BTW clearance is a bitch.
Old Dec 2, 2002 | 10:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Welcome,
go down to the bottom of the page and do a search for fast3rdgen, he has a setup similar to what you want, I'm doing the same, but with Hedman long tubes.
Camaro_383
Sep 11, 2015 11:28 PM
formula_novice
Sep 5, 2015 03:58 AM
