!!!!!some cat questions!!!!!!!
Old Feb 26, 2001 | 09:21 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
1)Anyone ever used Hedman Hedder 2000 series cat converter? Does it flow well compared to a cat like Random Techs?
2)Are Tpis's cats Random Techs?
3)Am I going to have a problem having my new cat put on? I have a Borla exhaust right now ,and if you dont know thier cat backs end about 6 inches from the cat, its a 3 inch system and where it ends there is a 2 1/2" pipe about 8" long welded to it and the other end is atached to the cat. I am getting a 3" cat and need to make that 2 1/2" pipe a 3" pipe. Will an exhaust shop be able to cut the weld where the 3" and 2 1/2" pipe are joined and put in a 8" section of 3" diameter pipe to weld to my catback without ruining it? And what about the other end of the 8" section of pipe where it connects to the cat, I want to get a direct fit cat which means there will be a 2 bolt flange on the cat, can they put a flange on the other end of the 8" section of pipe. Any Idea how much this is going to cost me???????
ALso are there sound differences with different converters? Because I want one that will give me the loudest exhaust.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
[This message has been edited by john5.7 87Iroc (edited February 26, 2001).]
Old Feb 27, 2001 | 08:39 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
Anyone? I need to buy the cat today. And I want the one that will be the loudest and best flowing but dont want to spend $200 if I dont have to. heres basically what I am looking at Catco, Random tech, Dynomax, Hedman, and Mor flo
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
