Cat-Back Weld vs Clamp
Old Feb 27, 2001 | 01:23 PM
Alan84TA's Avatar
I am getting ready to install a hooker catback system on my '85 TA.
1. Do they fit pretty good or do they need modification?
2. Will the clamps work ok without welding?
3. If I use the clamps can it be welded later without disassembling it?
Old Feb 27, 2001 | 05:49 PM
Dan87IROC-Z's Avatar
I used all clamps on mine and I haven't had any trouble yet (cat-back is 9 months old). On my friends 85 Z28 he had to have the cat-back welded where it intermediate pipe goes over the axle because if kept slipping off. So you mind want to consider welding that joint.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
