What is included in SLP installation kit??
Old Mar 1, 2001 | 05:04 PM
Mo's Avatar
Mo
I know it has gaskets and bolts, but what else? What in it makes it a requirement, like what does it include that I can't get somewhere else?
90 IROC 5.7l (L98)
ram air, K&Ns, air foil,Flows
LIKE A ROC
Old Mar 1, 2001 | 06:46 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I got mine w/o the install kit and I ended up calling up and getting the cat adapter (little 3" bend)
I already had gaskets, bolts and stuff and this was all I needed. The bolts are all different sizes so aftermarket 'kits' won't work. They are all 3/8-16 ranging between 3/4" to 1-3/4" with some in between. You can measure them and pick bolts up anywhere (I got allen heads for an easier fit)
I hear they give a 90 degree boot or some kind of heat sleeve for the coolant switch connector, but I modded my own by cutting and crimping a terminal on it and slipping a spark plug boot over it. Worked.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 2, 2001 | 05:54 PM
Mo's Avatar
Mo
I don't think i need the cat adapter, but how could I figure out what bolts I would need?
thanks
Old Mar 3, 2001 | 03:08 AM
JoelOl75's Avatar
Measure the flange of the headers when you get them (some have tubes added on so the lenths are all diff). add 1/2" to get bolt size. Don't go too big because the heads are blind tapped and it will bottom out.
'88 Camaro RS 2.8L
Old Mar 3, 2001 | 06:57 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The kit contains all gaskets, bolts, donut rings, and U-clamps needed for installation. If you get the AIR setup it also includes the necessary parts for that connection.
The kit does NOT include the cat adapter which in most cases is necessary. If you look at the angle the collector ends and look at the angle the cat-conv begins you may see about a 45 degree difference, this is where the adapter fits in.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 3, 2001 | 03:05 PM
Mo's Avatar
Mo
see, I think I'm gonna get the AL gaskets, so I'm trying to decide if I need to spend the $60 to get this kit and then have to spend another $35 or whatever for new gaskets, and possibly getting locking bolts too.
Old Mar 3, 2001 | 08:50 PM
Pukka's Avatar
The gaskets included in the kit work very good. Don't wknow what the locking bolts are used for, but the kit is worth the money based on simplicity. You could maybe save a bit by shopping around for the parts individually.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
