What is the best set of hedders ?
Old Mar 4, 2001 | 02:59 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
My car is 98% stock, but i want to put some headers on that will give me some tourqe and some throttle response, which are best ?
Old Mar 4, 2001 | 05:25 PM
Dan87IROC-Z's Avatar
A lot of people seem to think that the SLPs are the best, and I have to agree with them even though I have no first hand experience with them. I can say that I have been VERY happy with my Edelbrock TES Headers that I bought from Summit for $320 or so. If you have the money ($500+) to buy a set of SLPs, then you might want to consider it, but there are lots of people who spend less and are very happy with them.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 4, 2001 | 05:40 PM
98_1LE's Avatar
If you plan to stay close to stock then I would suggest the Edelbrocks, well unless you live in a place where they salt the roads alot in winter. The SLP's are stainless and will never rust. They also flow more if you plan to add more airflow later.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 5, 2001 | 06:06 AM
Jims83TA's Avatar
I have posted many topics like this one. I will tell you the results that I have had. Most people recommended the Eldebrock TES Hedders. They said they were the easiest to install. They also said that you should ceramic coat them, so that they will not erode and rust. Everyone who has spent less on the Eldebrock TES hedders seemed to be very happy. They have said that it is the best bang for your buck. Therefor I have decided to go with the Eldebrock TES hedders. I originally wanted the SLP hedders, but they are obviously expensive. If you have the money, then get the SLP's. But I have been recommended the Eldebrock TES's. I personally have no first hand experience with any of these hedders, but this is all the info that I have been told. Hope I helped.
Old Mar 5, 2001 | 01:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
For the cost of Edelbrock headers plus coating them, you can get SLP headers, which flow better, and have all 1 5/8" primaries instead of 1 1/2" primaries on the Edelbrock headers.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 5, 2001 | 09:11 PM
89GTA350's Avatar
I've put hedman hedders on my 350 GTA. They're not too expensive and I've got good results with a dynomax race magnum muffler. The only deception I have is for my muffler: too quiet!!! The race magnum serie muffler have a straight through desing and give and excellent air flow but that does'nt sound enought loud for me! But if you look for the air flow that's the right choice.
Old Mar 5, 2001 | 09:39 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Dude, I know, just like me you want to get responces to your Perticular post.Nothing wrong w/that.Also alot of people are ready to give you a lot of opinions(good,bad and ugly).Also nothing wrong w/that.You know that old saying: Opinions are like A-holes, everybody has one, and nobody wants to hear it,but you also can't live w/out at least one.
My point is, there are a lot of posts as far as the "header question". Scroll for them and look for them all. There's a lot of info in the old posts,and a lot of As...err, opinions on the subject.lol.
Really, read all of them and also the archives.
As far as my opinion. I love my TES. The difference from stock exhaust, is incredible!But w/a mod like headers you will benefit more w/a different Prom.There are even more opinions on that subject.
Just remember, ANY HEADERS ARE BETTER THAN YOUR STOCK MANIFOLDS!!!
mike
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch (going).
Old Mar 5, 2001 | 09:48 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
ok here is the deal...SLP headers are NOT 500+ bucks. no way. i got mine for like 349 i think. i had edelbrocks and i was EXTREMELY disappointed in them. the exhaust "ports" were sooooo small i could not believe it. they advertise them at like 1 5/8", but in reality they are like 1 3/8" IF THAT. and...they look like complete CRAP unless you get them coated. so take that 350 bucks and add 150-250 for coating them. quickly adds up to like 500-600+ for the edelbrocks.
the SLP ones are more initially but they DONT have to be coated since they are stainless. and the quality is AWESOME. they look kick a$$ and have really good construction, etc.
i would get teh SLPs over edelbrock any day. thats just my 2 cents of course, but i have had them both and there is just a huge difference in the two.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Mar 5, 2001 | 09:51 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
On, one more thing. If you're on a budget, don't worry about rust or coating or all that mess. Uncoated headers will last you many, many, many years, unless if you live in a state where there's a lot of snow and rain.And if you happen to live in such a state, than your headers will only last for about 5 years or so.
There is always things like www.por15.com.
Mike
Old Mar 5, 2001 | 11:01 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
SLP.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Mar 5, 2001 | 11:08 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
SLP headers are/were $470(including the instal kit) shipped to your door from the GP. I'm not sure if that deal is still on.They are about $450, regularly.Add $80 for the kit and S+H.Now you're looking at $600+.SLP ARE MUCH HARDER TO INSTALL!!!
TES cost me $350 shipped, and they are a breeze to slap on.You don't have to coat them,eather.
Are your stock manifolds coated? No.They are not.Unless you want your headers to look pretty, there's no need to coat them.SLP rust too.Most people that have the money to get SLPs, get them coated too. Why don't you ask them, why?
I'm not promoting TES or ay other Brand Name.Choose as you will, but keep in mind: Do I wan't the most popular headers? Do I want pretty headers? Do I want headers that easy to install? Do I want headers that I can use in the future in case I modify my motor?Do I want headers that wont cost me a $1000(PARTS+LABOR)
Remember, even if you install the headers yourself, it's still doesnt mean FREE instalation. Unless you consider your time FREE.
MIke
1990 Formula
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46)
Old Mar 6, 2001 | 08:33 AM
vortech305's Avatar
Some of u guys must be right i must be a freakin idiot. I thought coating a header was mainly to trap heat inside the header, thus flowing potential increases. I know there for dependability as well, so the headers dont corrode.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 6, 2001 | 09:35 AM
Slow88RS's Avatar
Edelbrock TES headers are a great improvement over the stock manifolds. Although my friend has an 89 Iroc-Z and ran a 14.2@96mph with just all the free mods (except ram air) and full exhaust. He has the SLP headers and an aerochamber catback. On my 88 rs i had a full edelbrock exhaust and was VERY pleased. The sound at idle was low but when you got on her she barked loud. I think the TES headers flow very well and almost as well as the SLP but not quite as good.
90 Iroc LB9 5spd G92
Dual Cats, 3.42 Borg Warner w/Posi, TPIS Airfoil, K&N, 160 Thermo, Mobil 1 Extreme Formula 0W-30 Synthetic Motor Oil, Home Made Ram Air, ACDelco Plugs, 8.8mm 300+ Accel "Race" Wires, Accel Cap And Rotor, Ported and Gasket Matched Plenum, TB Coolant Bypass, Advanced Timing To 10 BTC
Best ET(Not Corrected): 14.4 @ 94mph with 2.022 60ft
My 3rd Gen Web Page
Old Mar 6, 2001 | 11:53 AM
Kevin91Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Slow88RS:
Edelbrock TES headers are a great improvement over the stock manifolds. </font>
Anything is better than stock manifolds.
<font face="Verdana, Arial" size="2"> I think the TES headers flow very well and almost as well as the SLP but not quite as good.
</font>
They dont. See the reasons listed above about port size and primary tube size.
Old Mar 6, 2001 | 11:58 PM
JPrevost's Avatar
Car: 91 Red Sled
SLP, I wouldn't have it any other way.
, Jon (91 RS too many mods to list)
Old Mar 8, 2001 | 10:11 AM
dallasiroc's Avatar
Hello???? Hooker!!!!
They have been around the longest, and in my opinion have the best rep of all headers.
Old Mar 8, 2001 | 01:12 PM
theformula's Avatar
If it's not made of stainless steel, it is not worth getting. Anything else will rust within a year uncoated, and shortly thereafter if they are coated. Ceramic coated, jet hot. I've seen them rust. The guy I bought my blower from had Hooker long tubes sitting in his garage, jet hot coated. He never used them once, and they were brand new. They started to rust from the condensation! Just from sitting there. Unbelievable.
Headers are a major pita on our cars, if you get the slps you only have to do the job once. By the way, the SLPs outflow the Edelbrocks 7 days a week, twice on Sundays.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (4700rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited March 08, 2001).]
Old Mar 8, 2001 | 02:25 PM
Mike89GTA's Avatar
Get the SLP's if you have the money.
If you have dual cats then the SLP's will also be easier to install.. the Edelbrock TES dual cat setup doesn't include the pipes all the way to the cats, just two 90* turns where they come down out of the engine bay.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
