SLP header installation--how hard??
Old Mar 3, 2001 | 02:39 PM
Mo's Avatar
Mo
I have decided the cost difference is minimal btwn these headers and Hooker w/ the GP, so now I need to consider other factors before I make my final decision. So heres what I need to figure out:
1) From other posts i get the impression that SLPs are a PITA to put in, since I'm doing it myself, how much harder is it really?
2)clearance problems??
3)My other choice, Hooker, doesn't come with pipes to the cats, so i have to have a shop make some, will the pipes they bend (2.5") most likely be pretty crappy, or will they flow about the same as SLP's pipes??
Thanks a lot guys
90 IROC 5.7l (L98)
ram air, K, air foil,Flows
LIKE A ROC
[This message has been edited by Mo (edited March 03, 2001).]
Old Mar 3, 2001 | 08:58 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Don't know about Hookers, but SLP can give you everything you need (except the tools) straight out of the box. You may or may not have clearance problems with one of the driver's side headers rubbing against the steering column (Particularly on the 1 3/4" size. These are your options:
Replace the motor mounts
"Dimple" the header
Shave the steering column
Reposition the steering column (as once posted)
Installation is a PITA if you have never done this before, but certainly not impossible with the right tools (SLP sends very detailed instructions). Lastly I suggest you go with the 3/4 inch headers just in case you decide to mod your 350 or go with a bigger engine.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 5, 2001 | 09:59 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
teh SLP 1 3/4" ones touch the steering shaft...which if you have a dremel tool or a grinder or something you can fix . i dont want to bend or dent my header, so i am grinding a little bit off my steering shaft to make up for it i guess. the installation isnt that bad though...not any different than my edelbrocks that i had before.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Mar 8, 2001 | 05:36 PM
Mike89GTA's Avatar
My 1 3/4" SLP's came NOWHERE NEAR the steering shaft. Go figure..
Old Mar 8, 2001 | 07:58 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
mine barely rubs on the shaft. I did nothing and I don't notice. I can just see on the shaft where it has rubbed. I really did not have any major trouple putting them on. I can't imagine that any other brand would be way easier. the y pipe was kind of a bitch but only because I was by myself. but I still got it done.
"I don't trust anything that bleads for five day's and doesn't die"
88 iroc slp headers,borla catback,procharger to come soon.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
