everyone with hooker L/T headers please step inside
Old Mar 6, 2001 | 07:34 PM
bad camaro RS's Avatar
im running afr 195 cc heads what sparl plugs you useing? im having probs with plug wire clearence on last tube on drivers side but they are all a tight fit i dont wanna burn my $80 wires i tried to find accel shorty header plugs but they said they dont make em for aluminum heads i need threads to be 3/4" long thanks
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Mar 10, 2001 | 07:38 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
I'm using the Autolite 3924 plugs with my Edelbrock Performer RPM aluminum heads and Hooker long tubes. That is the plug Edelbrock recommends. Before I put my engine in the car I trial fitted the headers and noticed the close clearance on the #7 plug so I dimpled the tube a little. Ever since I got my timing and air/fuel ratio set right I haven't had a problem with melting my plug wire boots.
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
