Got my TES headers...
Old Dec 12, 2002 | 08:53 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
They finally came in yesterday, as well as my roller rockers and pushrods. I bolted them up and got to bolting up the Y-pipe, and I bolted on the driver's side first. On the passenger's side, there was a huge gap between the collector and the Y-pipe, so it would not bolt up. Any one else have this problem? Could it just be the two piece Y-pipe, and the way it is put together? Any help is appriciated,
-Berlinetta00
Old Dec 12, 2002 | 10:50 PM
EvilCartman's Avatar
Car: '82 Z28
Did you put back the little exhaust flapper? Said to in my instructions.
Old Dec 12, 2002 | 11:06 PM
Car: '84 Berlinetta
Engine: ZZ4
No, I didn't. I scrapped it when I took the emissions off over a year ago. Oops. I figure I can put something in its place...
Another thing, on the 305 head, which valve is the intake and which is the exaust? I thought the exaust was on the left and intake on the right but I could be wrong. Anyone know???
Old Dec 13, 2002 | 01:16 AM
papaford's Avatar
simply look at witch valve is closest to the intake port and thats the intake and of course vise versa for the exhaust.
Old Dec 13, 2002 | 10:35 AM
TBI305Camaro's Avatar
so does the TES not bolt up?? I was thinking about ordering them soon. I dont have any of the crap from the stock exhuast. Not sure what the "flapper" is. If they are a PITA to install I might go ahead and get hookers...or maybe even SLP.
Old Dec 13, 2002 | 01:00 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Mine bolted right in with no real problems to speak of, other than the typical ones common with working on cars, but I have a 350 though. I bought my headers for my 89 Formula 350, which had that flapper, but put them on my GTA which (if I recall correctly) did not have it. The Y-pipe is a real ***** to get in right, it took about 35 minutes to get it right, but it wasn't a big problem. What I did was, just start the bolts on the left so that the collector flanges are loose, then slide the right side up in there and start it's bolts. Then once all the bolts are started, I wiggled & jiggled the damn thing until I got a good seal at both collectors and then tightened all the bolts down till they were just past snug. That part sucked because all the blood in my hands & arms ran out, and they went to sleep about half way through. Then I clamped the pipes together with the supplied clamp, and tightened the collector bolts tight. After that I took it out and ran it up and down the road to get everything nice & hot, and brought it back in and loosened the collector bolts, and the clamp, shook it a bit more and bolted it all back together tight. Re-torqued the header flange bolts at the head, dropped the hood and spanked it a bit more. Since I installed them, I have had NO problems with them coming loose or any leaks, that was about 9 months ago. It just takes a little time & patience to get it in right. Good luck.
Old Dec 13, 2002 | 02:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Mine bolted up just fine.
Old Dec 13, 2002 | 03:07 PM
maybe ill get them after all. wish i could get them without AIR.
Old Dec 13, 2002 | 07:08 PM
88IROCARMY's Avatar
removing the air parts on the headers is eacy Cut-off wheel and spot weld. That's all
Old Dec 13, 2002 | 10:00 PM
Car: '84 Berlinetta
Engine: ZZ4
Yeah, I lost that butterfly valve somewhere... I just finished the install on it, and it turned out great. I just cut a piece of 2 1/4 pipe about 2 and 1/2 inches long, flared one end, put different gaskets in and presto! TES on the '84 without that annoying butterfly...
-Berlinetta00
Old Dec 13, 2002 | 10:04 PM
what is this butterfly?? I dont think my car had this.
Old Dec 13, 2002 | 10:54 PM
Car: '82 Z28
Vacuum operated valve to warm up the engine faster I believe... Mine was gutted already or it fell apart lol.
Old Dec 14, 2002 | 03:46 AM
Car: '84 Berlinetta
Engine: ZZ4
I don't think that the post 86 or 87 cars had them. The idea was that the motor would warm up faster if the exaust gasses were retained inside the exaust manifold by virtue of a vaccum operated butterfly valve, similar to a choke plate. It was wired to the emmisions and the electric carb, I believe. If you have TBI, it is less likely that you had one. It unevens the backpressure on the two sides of the engine, which leads me to belive that this butterfly could cause unwanted wear on the motor, but I could be wrong...
-Berlinetta00
Old Dec 14, 2002 | 09:53 AM
Car: 99 Formula
Axle/Gears: 342
I have that valve to in those headers, and it did nothing but rattle, so embarassing.
Old Dec 14, 2002 | 09:04 PM
Yeah mine didnt have that. If you car doesnt have this will the y pipe still bolt up?
Old Dec 15, 2002 | 04:38 AM
Car: '84 Berlinetta
Engine: ZZ4
The TES will bolt up without it, although it takes just a little innovation. Look in my post half way through this thread to see what I did.
Just about ready to start the Camaro after a 6-month long build up. Thats right.... a long six months without by beloved camaro to drive... All changing tomorrow. It ought to be the ride of a lifetime.
-Berlinetta00
Old Dec 15, 2002 | 10:08 PM
holmes677's Avatar
i have two of those laying around and im not sure which one to use. (im putting my exhaust on now, my bro took it off so i dont know which one goes on) one has a butterfly valve and a hose coming from it while the other is clear, straight though piece. my car is an 86 tpi, what do you guys think?
Old Dec 17, 2002 | 10:57 PM
holmes677's Avatar
anybody got a clue?
Old Dec 18, 2002 | 02:27 AM
Car: '84 Berlinetta
Engine: ZZ4
The butter fly goes on the passenger side of the engine. If you got rid of smog, just use a piece of straight pipe with a flange. The butterfly will just flap if you disconnected it, read above.
Hope this helps,
bamaboy0323
Sep 12, 2015 07:14 PM
crazyjoe
Aftermarket Product Review
Apr 10, 2001 11:53 PM
Stell1579
Feb 11, 2001 03:31 PM
IROCBandit
Jan 28, 2001 12:06 AM
Snapcase19
Nov 14, 2000 09:32 PM
