Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
TES Headers
Old Jan 25, 2001 | 08:51 PM
IROCBandit's Avatar
TES Headers
I just wanna know if the Edelbrock TES headers are worth the 300 they ask for em. also how hard are they to install on my car. im not too informed about headers for 89 IROC's so im up for any new ideas. kind of a limited budget so i can't spend a big amount, thanks for any imput.
1989 IROC, 350 TPI. K&N and Flowmaster.
Old Jan 25, 2001 | 09:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If you get the TES you have to get them jetcoated or they will S**t out on you in a few years. Installation is a B***h but easy if you take your time and think stuff out.
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, ,Crane Gold 1.6 RR's, BBK 52mm TB , MSD 22# Injectors ,Hoping for 13.5
Old Jan 25, 2001 | 09:55 PM
IROCBandit's Avatar
what other headers would you advise, or would jet coating be the best bet.
Old Jan 25, 2001 | 11:16 PM
mcconahay37's Avatar
I agree that you need to get the Edelbrocks coated if you go with them. The guy running the performance shop I hang around has put on 4 or 5 of these systems and has had to remove them after a little over a year, because they were cracking. He's had good luck with Hedman's system. Try them if you need AIR. Hooker makes a great shortie header, but the y-pipe has to be custom made. If you have the cash and staying smog legal isn't necessary, get the Hooker Super Competition coated headers. They are long tubes with 1 3/4" primaries that will last forever. Again the y-pipe needs to be made. They sound better than shorties, and when you start heavilly modding your engine or putting in a bigger one, they'll be ready to handle it.
Old Jan 26, 2001 | 12:50 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
On a 350 TPI, go with SLP's headers. Edelbrocks are too small. Check the GP forum for the deal on SLP headers right now.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 26, 2001 | 08:14 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I would consider the Edelbrocks as a "cheap" alternative to good headers. The primaries may be 1 5/8" advertised, but with all the welding slag and air tubes, there's no way. I just pulled mine, and after looking at them and their lousy quality, I wish I'd sucked it up and went with the SLPs.
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Jan 26, 2001 | 09:10 AM
Scott C's Avatar
Unless you want severely rusted headers in about one year, you MUST get them coated! BUT, the cost to coat them and the cost of the TES adds up to as much or more than a set of SLP stainless steel headers and y-pipe!
I've gone through three sets of Edelbrock TES and will never buy them again. I currently have a set of coated SLPs and I'll never go back.
Old Jan 26, 2001 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Summit website shows Hooker 2055's (HOK-2055) for $350. Those should include AIR & O2 sensor fittings. In the catalog, they say add $185 for coating.
Although they are 1-5/8" primaries, I doubt they would be restrictive to most. Certainly not to the 305 guys.
Anyone have them, or considered them?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, TBD headers & hi-flow cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Jan 26, 2001 | 01:57 PM
IrocStan's Avatar
I bought my Edelbrocks 3 1/2 years ago because they were $313 vs like $450+ for SLP's. I wanted the 1.75 primaries, but the added cost wasn't worth it IMO. It is true that the intry on the TES headers is kinda messy. I grinded quite a bit of it out before installation. There is no coating on mine and I have had no problems w/ cracking etc. Only light surface rust. I don't think that they are as bad as everyone says they are. I recomend cleaning up the entry though.
87 IROC 350, 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, SSM sfc's, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Goal: 12.999
Old Jan 26, 2001 | 03:31 PM
Scott C's Avatar
IrocStan,
Have you looked at your y-pipe lately? I'll bet it's pretty nasty by now! If it's not, I'm guessing you don't drive that car in the winter! The y-pipe is going to be the first part to rust through and crack in half.
Old Jan 26, 2001 | 05:03 PM
IrocStan's Avatar
Yeah, come to think of it, the y-pipe is pretty nasty. The y-pipe sliped my mind because the rest looked so good. No hole or anything yet. Did I mention that I am still on the original gaskets? There is a slight leak that I only hear when beside some thing, like a concrete wall or passing a car etc. I am pleased with them. I reccomend them to since you are on a limited budget. But if you plan on going crazy with mods in the future, get the 1.75 SLPs or Hooker long tubes. I wish I had a bigger set now, but I don't regret buying them when I did. The price difference was insane 3.5 years ago. Now the prices are closer. It is just of those things. You say, "Oh, I'll get headers. They are only $300. But wait, for a little more I can have a better set." It never ends. Just decide what you plan on doing in the future. I know that the SLP's were on sale not too long ago. I think they were $399.
87 IROC 350
Mods: 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, boxed rear suspension pieces, urethane bushings everywhere.
Recent stuff: SSM sfc's, Homemade relocation brackets, Ported SLP runners, ported base, EGR!
Current/future projects: homemade torque arm, and 27x10 Hoosiers (need wheels!), and Prom Burning
Planning new engine build, possibly 383 w/ TFS 23*
Old Jan 27, 2001 | 10:06 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I have the Hooker 2055 headers on my '87 IROC (305TPI/A4) and love them. They don't have the restrictions inside the primary tubes like the Edelbrocks do. I did grind down the air tubes some since they were sticking about 1/8"-1/4" into the primaries, but that was it. I picked up torque and horsepower through the whole powerband of the engine (1200 to 5000 rpm). With a 2400 stall converter, the low-end at WOT doesn't matter anyhow.
I had mine Jet-Hot coated for thermal and rust protection, and the headers still look brand new. The Y=pipe isn't in nearly as good of condition due to a small long-term coolant leak and the distance from the engine (doesn't get hot enough to cook off anything that sticks to it). The headers fit very good and should support my upcoming 350 engine nicely...
Greg Westphal
'87 IROC 305TPI/A4
Old Jan 28, 2001 | 12:06 AM
Dan87IROC-Z's Avatar
All I have to say is that 1 year after installing my TES Headers I have been nothing but happy with them. My friend has had them for over 2 years now (also non-coated) and he is also very happy with them. We both haven't had any problems with them at all and the performance gains we have been more than happy with!! I give the Edelbrock TES Headers, my thumbs up!!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
NZKnight
Oct 15, 2015 02:47 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
bamaboy0323
Sep 12, 2015 07:14 PM
