header installation
Old Mar 17, 2001 | 12:15 AM
Stormshadow GTA's Avatar
header installation
how difficult is it to install headers on a 87 gta.i don't want to put any on if it is a bitch,are there any good y pipes that attach to the stock manifolds
Old Mar 17, 2001 | 12:22 AM
Dan87IROC-Z's Avatar
After doing an car cam swap, that involved pulling the heads off, doing headers is a piece of cake. If you have a long weekend, a set of jack stands, some patience, basic hand tools, a buddy to help, and some beer, you can do it without much hassle. There are a few bolts that are a PITA to get to and you might have to disconnect the steering column to get the driver's side header in. Other than that, you can do it without too much trouble.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 17, 2001 | 08:17 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, just like Dan said, it's not that hard at all. Just take your time and you can complete it in a weekend or so. It might look like a hassle but once you start you will realize that it's pretty easy. Hell, on my Z, the passenger side was the EASY side to do. Go figure. Have fun.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
