Jet-Hot Coatings. Which one?
I just bought SLP 1 3/4 headers and want to get them coated. I like the sterling silver finish but it isn't available in the Jet-Hot 2000 finish. I was told I should get the higher temperature coating because I plan on installing a supercharger later and the Jet-Hot 1300 coating might not be enough. Does anyone have a supercharged engine running the Jet-Hot 1300 sterling silver coating on there headers? Anybody know how hot of exhaust temperatures a supercharged engine has?
Thanks.
92 Formula 5.7 T-tops
Flowmaster
Other secret mods.
Thanks.
Flowmaster
Other secret mods.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Exhaust temp will be a good indication on jetting reguardless if it's naturally asperated or supercharged.
Typical exhaust at WOT should be 1150-1300 with 1400 being the absolute max without starting to destroy the engine. If it's too hot then jet up the fuel mixture and let it run a bit rich.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Baron
Jan 29, 2001 08:59 AM
