Porting header ports...
Old Mar 22, 2001 | 10:31 AM
wickedfbody's Avatar
Anyone ever tried porting the sqaure ported headers to fit on D-shaped ports?
A buddy of mine opened up the ports on his 1 3/4" SLP headers to make them fit on his FastBurn heads' D-shaped ports. He grinded quite a bit away with a Dremel and was thinking about doing this to mine. I have a similar setup/problem. The welds were grinded down but of course not completely. Seems like he opened the ports a bit bigger than the heads but looks good regardless.
Any thoughts on this?
Old Mar 22, 2001 | 10:45 AM
FormulaJoe's Avatar
Im glad to hear that someone else has done this. I am in the process of doing this with my 1 3/4 SLPs and Fast Burn heads and I think it will work fine.
Everyone says that you need special headers with the fastburn heads, but it looks to me like you can do some hogging and make it work.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Mar 22, 2001 | 03:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I reshaped my header ports a little bit on my SLP 1 3/4" for my L98 heads. Its not a big deal. The 1 3/4" size aleady fits over the exhaust port pretty well, unlike some other company's 1 5/8" and 1 1/2" headers.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 22, 2001 | 03:12 PM
Yeah it looks like it would work. My buddy used a really small cutting bit on his Dremel so it doesn't look very pretty. Regardless the ports are now opened up so I think I'll try it.
Anyone else?
Old Mar 26, 2001 | 09:33 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Some porting would be benifitial if done correctly, but simple 'port matching' can actually hurt power on street cars due to reversion (when the pressure wave travels back up the pipe and pushes intake charged air back out of the cylinder)
Leaving the exhaust port on the head somewhat smaller than the hedder inlet fight reversion because the pressure wave travels along the outside of the tube (just like voltage and current in electic circuits, voltage {pressure} tavels along the outside of the conductor, while current {flow} travels through the center)
The outlet on the head is not the biggest restriction in the system. Valve size and basic bowl porting/short side radius work is more benifitial to start with.
[This message has been edited by JoelOl75 (edited March 26, 2001).]
Chad Speier
Sep 24, 2015 12:32 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
