Headers
Old Mar 23, 2001 | 07:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Headers
Are there any headers for my car that DONT have the EGR ports/holes in them?
Old Mar 23, 2001 | 08:35 PM
SUPER-SPORT-CHEVY's Avatar
Yea you can get some shorties that dont have egr hookups but they need to be pro installed.
Old Mar 23, 2001 | 10:53 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I thought that headers connected only to the exhaust ports. HEADS have connections for EGR.....right?
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 23, 2001 | 10:54 PM
Pukka's Avatar
At least on thirdgen F-bodys
Old Mar 24, 2001 | 10:17 AM
no were talking no emmisions crap. the little lines that go out of the exhaust manifold not the head.
Old Mar 24, 2001 | 11:00 AM
kevinc's Avatar
Car: 1982 Z28
Ah, you're talking about AIR fittings. Seems like SLP and Hooker make headers without these, probably others out there also.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Mar 25, 2001 | 01:22 AM
taliesian's Avatar
Hedman makes a set of 1 5/8 shortie headers with no smog junk on them, it took me and my friend around 2 hours to install them, I would recomend a high torque mini starter also for clearance. I ground a good chunk of my starter off to get it to fit.
Old Mar 25, 2001 | 03:32 PM
HrdRockA4305's Avatar
Rookie question here, what are those tubes for anyway? My guess was its some sorta EGR thing but the way the tubes were routed it didn't look like something running that high of a temp (rubber hoses probably don't carry hot exhaust i'm guessing). Is that like some kind of air injection into the exhaust? The look like they go into the smog pump, could somone fill me in here?
88 Base Camaro
305 Auto
All Stock....for now
Old Mar 28, 2001 | 10:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Air injection. Helps burn any left-over hydrocarbons in the exhaust. Also goes to cat, helps improve its catalyzing effectivenss.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 29, 2001 | 05:11 PM
KW87GTA's Avatar
Hey, I know that SLP does make a set, and they are stainless so that's good. As for what they are; they are the Air Injection Reaction system that flows clean air from the smog pump into the headers and into the cat to burn off unburned fuel. This reduces harmful emissions. Other than that all they do is add weight in the front end and clutter the hell out of your bay. If you can get away without having them get rid of it all, but if you are in a state that has emissions be careful when it comes inspection time. Have fun. Now does anyway, know where the AIR that comes out of the cat goes. I wasn't able to quickly locate it, and want to plug both it and the headers AIR fittings so that I can disconnect the smog pump belt, but be able to uncap them and put the belt back on when it is time for inspection as well as of course swap back in a cat instead of a gutted one. Thanks and have fun.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC,
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
