HELLLLLP!!
Old Mar 31, 2001 | 05:32 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
HELLLLLP!!
I am removing my smog pump on a 92 r.s. w/a 305 t.b.i. I have the belt off but cann't find out what the tube that hooks up to the smog pump is. What is it and how do I remove it? thank you twells
Old Mar 31, 2001 | 05:48 PM
Dan87IROC-Z's Avatar
On my 87 IROC L98, the tube on the back of the smog pump attaches to the bottom of the diverter valve assembly. The diverter valve is that black box thing with all the emissions tubes comming out of it, it sits directly above the smog pump.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
donaldw
Jul 9, 2008 01:11 AM
clarkspecproco
Aug 12, 2005 07:53 PM
burnoutrpm
Mar 8, 2001 09:38 AM
rondubbs
Oct 29, 2000 12:17 PM
