AIR/Smog Pump & Headers
Old Apr 4, 2001 | 12:43 PM
Chris 611's Avatar
I am considering removing the AIR/Smog pump from my ’91 Formula (5.7L). I have read some of the other posts, and it appears that this will not affect the computer or running of the engine (Let me know if you think differently). I was curious if anyone knows what kind of headers I can get for the car that do not have the AIR tubes. Any help would be greatly appreciated. Thanks.
Old Apr 4, 2001 | 01:46 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
SLP sells 1 3/4" headers w/o a.i.r. I'm not sure about your other question but go check out these headers at slponline.com. Twells
Old Apr 4, 2001 | 03:21 PM
KW87GTA's Avatar
Hi, to my knowledge, there should be no problems with removing that stuff, just make sure that if you dissconnect them you plug up the AIR lines that come back to the engine so that no exhaust trickles back up. Also, taking these out might cause you to burn up your cat due to the presence of unburnt fuel. You might also think about gutting the cat and placeing a pipe either in it or just remove the cat totally. Good luck.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Apr 5, 2001 | 03:15 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Anybody ran their car through an emmissions test after removing the AIR crap. My 92 GMC truck 350 doesn't have any AIR on it. So I thought about removing mine from the camaro and ordering the GM under hood stickers for my truck and putting them on my car. My inspection station doesn't look under the hood. But I don't want to peg the guage on their test equipment and have to put the crap back on either.
91 Camaro RS 5.0L Black Convertible 700R4. Owned 3 months bought from 1 owner girl. Working on that stock part.
Old Apr 6, 2001 | 12:00 PM
FATZ_86er's Avatar
if you remove that smog pump which is a graet idea i strongly suggest that you remove all lines, hoses and al that other epa juk that yu dont need . a buddy of mine removed his smog pump on his truck and didnt remove all the what lines and tubes and his engine blew b/c of this so be careful
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
